After installing sdkmanager_1.8.0-10363_amd64.deb
on my ubuntu 18.04, I run sdkmanager
but no GUI shows up.
Since I could not find any log message, I have no idea to fix the issue.
I could successfully run GUI at least with sdkmanager 1.7.1-8928
$ sdkmanager
Gtk-Message: 02:08:50.725: Failed to load module "canberra-gtk-module"
Gtk-Message: 02:08:50.726: Failed to load module "canberra-gtk-module"
sdkmanager
CLI also failed with the error like below:
$ sdkmanager --cli install --downloadfolder ~/Downloads/nvidia/sdkm_downloads/ --checkforupdates false --datacollection disable --license accept --product Jetson --version 4.6.2 --targetos Linux --target JETSON_AGX_XAVIER --flash all --exitonfinish
To initiate login process open https://static-login.nvidia.com/service/default/pin?user_code=10409633 in a browser or scan the QR code on your handheld device then login with your NVIDIA Developer account. SDK Manager will start once done.
Login user code: 10409633. (valid for: 10 minutes).
? SDK Manager is waiting for you to complete login. Generate a new login user code
New login code generated
To initiate login process open https://static-login.nvidia.com/service/default/pin?user_code=77511134 in a browser or scan the QR code on your handheld device then login with your NVIDIA Developer account. SDK Manager will start once done.
Login user code: 77511134. (valid for: 10 minutes).
1) Generate a new login user code
2) Display the QR Code
3) Cancel login
Answer: 1
Waiting for user information from NVIDIA authentication server...
Retrieving user information...
Loading and processing available products...
Login succeeded.
Loading user information...
User information loaded successfully.
Loading server data...
Failed to get configuration file from the server. Please check your network connectivity.
