I’ve been using the Sdkmanager docker image to flash my AGX.
docker run -it --rm --privileged \ -v /dev/bus/usb:/dev/bus/usb/ -v /dev:/dev -v $HOME/sdkmanager:/home/nvidia:slave \ sdkmanager:1.8.0.10363-Ubuntu_18.04 \ --cli install --offline --downloadfolder /home/nvidia/4.5.1 --checkforupdates false --datacollection disable --license accept \ --product Jetson --version 4.5.1 --targetos Linux --target JETSON_AGX_XAVIER \ --flash all --exitonfinish
This week it returns error when trying to install libxml2-utils during the flash process.
Turns out sdkmanager will download an install script to /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh
(RED FLAG) and execute it.
The script did not run apt update
so the apt install libxml2-utils
fails.
It is a known issue that libxml2-utils was a missing dependency and it seems the script was deployed recently to “fix” this issue.
Here are my suggestion:
- sdkmanager should not download and execute script from the internet
- missing dependency should be fixed by updating the .deb and docker image rather than a script
