Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
I rebuild the kernel. When I try to flash new image with SDKmanager, it complains " You do not have permission to access the download folder". I back to original image, still same error.
Could you please help to look at this issue.
Dear @user121210,
Is the download folder refers sdkm_downloads? If so, could you check the permission of the folder.
Also, if possible can you uninstall the drive release using sdkmanager, delete the download, installation, logs folders and re flashing the target.
Thanks. I uninstall the drive and reinstall again, now sdkmanager works.
Now I have a new issue, after the new image is flashed into Xavier, I follow the Dirve OS SDK instructions trying to enable GUI,
sudo apt-get update
sudo apt-get install gdm3 ubuntu-unity-desktop
and modify custom.conf file, then reboot the system, but GUI does not work. I got below message:
[ OK ] Created slice User Slice of nvidia.
Starting User Manager for UID 1000…
[ OK ] Started Session 1 of user nvidia.
[ OK ] Started User Manager for UID 1000.
[ OK ] Started Wait for Network connected to WWW to be Configured…
[ OK ] Reached target Network is Online.
Starting startup for DUV3…
[ OK ] Started crash report submission daemon.
Starting Sync/Update RTC time…
[ OK ] Started startup for DUV3.
[ OK ] Created slice User Slice of gdm.
Starting User Manager for UID 120…
[ OK ] Started Session c1 of user gdm.
[ OK ] Started User Manager for UID 120.
Stopping User Manager for UID 1000…
[ OK ] Stopped User Manager for UID 1000.
[ OK ] Removed slice User Slice of nvidia.
Stopping User Manager for UID 120…
[ OK ] Stopped User Manager for UID 120.
[ OK ] Removed slice User Slice of gdm.
[ OK ] Started Session c2 of user gdm.
Starting Daemon for power management…
[ OK ] Started Daemon for power management.
[ OK ] Started Session c3 of user gdm.
[ OK ] Started Session c4 of user gdm.
[ OK ] Started Session c5 of user gdm.
[ OK ] Started Session c6 of user gdm.
