Helle @wichiu
This morning I made all changes you request to me.
$ cat ~/.ssh/config
Host fc00:1:1::2 fc00:1:1:0::2
PreferredAuthentications password
PasswordAuthentication yes
PubkeyAuthentication no
KbdInteractiveAuthentication no
NumberOfPasswordPrompts 1
Host *
AddressFamily inet6
ConnectTimeout 10
StrictHostKeyChecking no
UserKnownHostsFile /dev/null
I have to add more options, at the end I succeed to connect to my jetson with command
as SDK Manager did. let’s see the print outputs
sshpass -p root ssh root@fc00:1:1::2
Warning: Permanently added ‘fc00:1:1::2’ (ED25519) to the list of known hosts.
-bash-5.2#
But SDK Manager still exit with the same errors
15:27:39 INFO: Flash Jetson Linux - flash: [ 0.5417 ] Sending blob
15:27:42 INFO: Flash Jetson Linux - flash: [ 3.7987 ] RCM-boot started
15:27:42 INFO: Flash Jetson Linux - flash: /home/sminko/nvidia/nvidia_sdk/JetPack_7.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra
15:27:42 INFO: Flash Jetson Linux - flash: ***************************************
15:27:42 INFO: Flash Jetson Linux - flash: * *
15:27:42 INFO: Flash Jetson Linux - flash: * Step 3: Start the flashing process *
15:27:42 INFO: Flash Jetson Linux - flash: Mounting NFS folder from this host
15:27:42 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:27:43 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:27:45 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:27:46 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:27:48 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:27:49 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:27:50 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:27:52 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:27:53 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:27:54 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:27:56 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:27:57 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:27:58 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:28:00 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:28:01 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:28:14 INFO: Flash Jetson Linux - flash: Waiting for device to expose ssh …Waiting for device to expose ssh …Run command: flash on fc00:1:1:0::2
15:28:14 INFO: Flash Jetson Linux - flash: 15:28:14.410 - Debug: Debug log saved to /tmp/tmp.caYoKqYbli.
15:29:51 INFO: Flash Jetson Linux - flash: 15:29:51.204 - Debug: Device should have booted into initrd kernel now. However, the host cannot connect to its ssh server
15:29:51 ERROR: Flash Jetson Linux - flash: 15:29:51.209 - Error: Command failed: sshpass -p root ssh root@fc00:1:1:0::2. Check your network setting (VPN, firewall,…) to make sure the device can ssh root@fc00:1:1:0::2
15:29:51 INFO: Flash Jetson Linux - flash: 1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
15:29:51 INFO: Flash Jetson Linux - flash: link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
15:29:51 INFO: Flash Jetson Linux - flash: inet 127.0.0.1/8 scope host lo
15:29:51 INFO: Flash Jetson Linux - flash: valid_lft forever preferred_lft forever
15:29:51 INFO: Flash Jetson Linux - flash: inet6 ::1/128 scope host noprefixroute
15:29:51 INFO: Flash Jetson Linux - flash: 2: enp1s0: mtu 1500 qdisc mq state DOWN group default qlen 1000
15:29:51 INFO: Flash Jetson Linux - flash: link/ether 68:05:ca:e2:93:1c brd ff:ff:ff:ff:ff:ff
15:29:51 INFO: Flash Jetson Linux - flash: 3: enp5s0f2np2: mtu 1500 qdisc mq state DOWN group default qlen 1000
15:29:51 INFO: Flash Jetson Linux - flash: link/ether 00:68:eb:b6:5d:93 brd ff:ff:ff:ff:ff:ff
15:29:51 INFO: Flash Jetson Linux - flash: 4: eno1: mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
15:29:51 INFO: Flash Jetson Linux - flash: link/ether 00:68:eb:b6:5d:90 brd ff:ff:ff:ff:ff:ff
15:29:51 INFO: Flash Jetson Linux - flash: altname enp0s31f6
15:29:51 INFO: Flash Jetson Linux - flash: 5: enx98a44e88a82f: mtu 1500 qdisc fq_codel state UP group default qlen 1000
15:29:51 INFO: Flash Jetson Linux - flash: link/ether 98:a4:4e:88:a8:2f brd ff:ff:ff:ff:ff:ff
15:29:51 INFO: Flash Jetson Linux - flash: 6: wlx00e04c5ac673: mtu 1500 qdisc noqueue state UP group default qlen 1000
15:29:51 INFO: Flash Jetson Linux - flash: link/ether 00:e0:4c:5a:c6:73 brd ff:ff:ff:ff:ff:ff
15:29:51 INFO: Flash Jetson Linux - flash: inet 172.17.48.29/19 brd 172.17.63.255 scope global dynamic noprefixroute wlx00e04c5ac673
15:29:51 INFO: Flash Jetson Linux - flash: valid_lft 5718sec preferred_lft 5718sec
15:29:51 INFO: Flash Jetson Linux - flash: inet6 fe80::2d94:b990:77ac:b7da/64 scope link noprefixroute
15:29:51 INFO: Flash Jetson Linux - flash: 7: br-a9d971adbdb6: mtu 1500 qdisc noqueue state DOWN group default
15:29:51 INFO: Flash Jetson Linux - flash: link/ether fa:17:5b:99:72:ef brd ff:ff:ff:ff:ff:ff
15:29:51 INFO: Flash Jetson Linux - flash: inet 172.20.0.1/16 brd 172.20.255.255 scope global br-a9d971adbdb6
15:29:51 INFO: Flash Jetson Linux - flash: 8: br-b7cc4290cdfd: mtu 1500 qdisc noqueue state DOWN group default
15:29:51 INFO: Flash Jetson Linux - flash: link/ether a2:fc:60:18:49:ef brd ff:ff:ff:ff:ff:ff
15:29:51 INFO: Flash Jetson Linux - flash: inet 172.19.0.1/16 brd 172.19.255.255 scope global br-b7cc4290cdfd
15:29:51 INFO: Flash Jetson Linux - flash: inet6 fe80::a0fc:60ff:fe18:49ef/64 scope link
15:29:51 INFO: Flash Jetson Linux - flash: 9: docker0: mtu 1500 qdisc noqueue state DOWN group default
15:29:51 INFO: Flash Jetson Linux - flash: link/ether 56:4e:18:0f:f4:bc brd ff:ff:ff:ff:ff:ff
15:29:51 INFO: Flash Jetson Linux - flash: inet 172.18.0.1/16 brd 172.18.255.255 scope global docker0
15:29:51 INFO: Flash Jetson Linux - flash: 42: enx626032692564: mtu 1500 qdisc fq_codel state UP group default qlen 1000
15:29:51 INFO: Flash Jetson Linux - flash: link/ether 62:60:32:69:25:64 brd ff:ff:ff:ff:ff:ff
15:29:51 INFO: Flash Jetson Linux - flash: inet6 fc00:1:1::1/64 scope global
15:29:51 INFO: Flash Jetson Linux - flash: inet6 fe80::6060:32ff:fe69:2564/64 scope link
15:29:51 INFO: Flash Jetson Linux - flash: inet6 fe80::2/64 scope link
15:29:51 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /home/sminko/.nvsdkm/replays/scripts/JetPack_7.2_Linux/NV_L4T_JETSON_LINUX_FLASH_COMP.sh; [error]: chown: warning: ‘.’ should be ‘:’: ‘root.root’
15:29:51 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
15:29:51 INFO: Flash Jetson Linux - flash: [host] [ 17.56 GB used. Disk Avail on Partition /dev/nvme1n1p2: 129.85 GB ]
15:29:51 INFO: Flash Jetson Linux - flash: [ NV_L4T_JETSON_LINUX_FLASH_COMP Install took 8m35s ]
15:29:51 ERROR: Flash Jetson Linux - flash: command error code: 11
15:29:51 DEBUG: Flash Jetson Linux - flash: command terminated with error
15:29:51 SUMMARY: Flash Jetson Linux - flash: Installation failed.
