SDKManager in command line can not set proxy
I refer to the following link to use the sdk manager docker to flash orin
https://docs.nvidia.com/sdk-manager/docker-containers/index.html#download-and-install
But I don’t konw how to set the proxy in command line. The document doesn’t give any example.
Just run
sdkmanager --settings
It gives you a text UI for configuration:
davey@dave-yu-nvidia-pc:~/Downloads/dts$ sdkmanager --settings
Proxy Settings
- Proxy Mode:
❯ System configuration
  Manual configuration
  * Proxy for apt commands should be defined at: /etc/apt/apt.conf.d/proxy.conf
