Here is the error log I get when i try to install skimage but this seems to be the same error message i get when trying to install keras as well. I hope that in correcting it once, that it will fix all similar problems.
aliger@aliger:~$ pip install scikit-image
Defaulting to user installation because normal site-packages is not writeable
Collecting scikit-image
Using cached scikit-image-0.18.1.tar.gz (29.7 MB)
Installing build dependencies ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /tmp/pip-standalone-pip-8vojzic3/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-efabbijr/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- wheel 'setuptools<=51.0.0' 'Cython>=0.29.18' 'numpy==1.16.5; python_version=='"'"'3.7'"'"'' 'numpy==1.17.3; python_version=='"'"'3.8'"'"'' 'numpy==1.19.3; python_version=='"'"'3.9'"'"'' 'numpy; python_version>='"'"'3.10'"'"''
cwd: None
Complete output (680 lines):
Ignoring numpy: markers 'python_version == "3.7"' don't match your environment
Ignoring numpy: markers 'python_version == "3.9"' don't match your environment
Ignoring numpy: markers 'python_version >= "3.10"' don't match your environment
Collecting wheel
Using cached wheel-0.36.2-py2.py3-none-any.whl (35 kB)
Collecting setuptools<=51.0.0
Using cached setuptools-51.0.0-py3-none-any.whl (785 kB)
Collecting Cython>=0.29.18
Using cached Cython-0.29.23-py2.py3-none-any.whl (978 kB)
Collecting numpy==1.17.3
Using cached numpy-1.17.3.zip (6.4 MB)
Building wheels for collected packages: numpy
Building wheel for numpy (setup.py): started
Building wheel for numpy (setup.py): finished with status 'error'
command: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/setup.py'"'"'; __file__='"'"'/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-9ucc75ax
cwd: /tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/
Complete output (321 lines):
Running from numpy source directory.
blas_opt_info:
blas_mkl_info:
customize UnixCCompiler
libraries mkl_rt not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
blis_info:
libraries blis not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
openblas_info:
libraries openblas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_3_10_blas_threads_info:
Setting PTATLAS=ATLAS
libraries tatlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_3_10_blas_info:
libraries satlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_blas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_blas_info:
libraries f77blas,cblas,atlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
accelerate_info:
NOT AVAILABLE
/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/numpy/distutils/system_info.py:690: UserWarning:
Optimized (vendor) Blas libraries are not found.
Falls back to netlib Blas library which has worse performance.
A better performance should be easily gained by switching
Blas library.
self.calc_info()
blas_info:
libraries blas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
Blas (http://www.netlib.org/blas/) libraries not found.
Directories to search for the libraries can be specified in the
numpy/distutils/site.cfg file (section [blas]) or by setting
the BLAS environment variable.
self.calc_info()
blas_src_info:
NOT AVAILABLE
Blas (http://www.netlib.org/blas/) sources not found.
Directories to search for the sources can be specified in the
numpy/distutils/site.cfg file (section [blas_src]) or by setting
the BLAS_SRC environment variable.
self.calc_info()
NOT AVAILABLE
/bin/sh: 1: svnversion: not found
non-existing path in 'numpy/distutils': 'site.cfg'
lapack_opt_info:
lapack_mkl_info:
NOT AVAILABLE
openblas_lapack_info:
NOT AVAILABLE
openblas_clapack_info:
libraries openblas,lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
flame_info:
libraries flame not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_3_10_threads_info:
libraries lapack_atlas not found in /usr/local/lib
libraries tatlas,tatlas not found in /usr/local/lib
libraries lapack_atlas not found in /usr/lib
libraries tatlas,tatlas not found in /usr/lib
libraries lapack_atlas not found in /usr/lib/aarch64-linux-gnu
libraries tatlas,tatlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_3_10_threads_info'>
NOT AVAILABLE
atlas_3_10_info:
libraries satlas,satlas not found in /usr/local/lib
libraries satlas,satlas not found in /usr/lib
libraries satlas,satlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_3_10_info'>
NOT AVAILABLE
atlas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_threads_info'>
NOT AVAILABLE
atlas_info:
libraries f77blas,cblas,atlas not found in /usr/local/lib
libraries f77blas,cblas,atlas not found in /usr/lib
libraries f77blas,cblas,atlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_info'>
NOT AVAILABLE
lapack_info:
libraries lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/numpy/distutils/system_info.py:1712: UserWarning:
Lapack (http://www.netlib.org/lapack/) libraries not found.
numpy/distutils/site.cfg file (section [lapack]) or by setting
the LAPACK environment variable.
if getattr(self, '_calc_info_{}'.format(lapack))():
lapack_src_info:
NOT AVAILABLE
Lapack (http://www.netlib.org/lapack/) sources not found.
numpy/distutils/site.cfg file (section [lapack_src]) or by setting
the LAPACK_SRC environment variable.
NOT AVAILABLE
/usr/lib/python3.8/distutils/dist.py:274: UserWarning: Unknown distribution option: 'define_macros'
warnings.warn(msg)
running bdist_wheel
running build
running config_cc
unifing config_cc, config, build_clib, build_ext, build commands --compiler options
running config_fc
unifing config_fc, config, build_clib, build_ext, build commands --fcompiler options
running build_src
build_src
building py_modules sources
creating build
creating build/src.linux-aarch64-3.8
creating build/src.linux-aarch64-3.8/numpy
creating build/src.linux-aarch64-3.8/numpy/distutils
building library "npymath" sources
get_default_fcompiler: matching types: '['gnu95', 'intel', 'lahey', 'pg', 'absoft', 'nag', 'vast', 'compaq', 'intele', 'intelem', 'gnu', 'g95', 'pathf95', 'nagfor']'
customize Gnu95FCompiler
Found executable /usr/bin/gfortran
customize Gnu95FCompiler using config
C compiler: aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC
compile options: '-Inumpy/core/src/common -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -I/usr/include/python3.8 -c'
aarch64-linux-gnu-gcc: _configtest.c
aarch64-linux-gnu-gcc -pthread _configtest.o -o _configtest
success!
removing: _configtest.c _configtest.o _configtest.o.d _configtest
_configtest.c:1:5: warning: conflicting types for built-in function ‘exp’; expected ‘double(double)’ [-Wbuiltin-declaration-mismatch]
1 | int exp (void);
_configtest.c:1:1: note: ‘exp’ is declared in header ‘<math.h>’
+++ |+#include <math.h>
1 | int exp (void);
/usr/bin/ld: _configtest.o: in function `main':
/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/_configtest.c:6: undefined reference to `exp'
collect2: error: ld returned 1 exit status
failure.
1 | int exp (void);
1 | int exp (void);
aarch64-linux-gnu-gcc -pthread _configtest.o -lm -o _configtest
success!
creating build/src.linux-aarch64-3.8/numpy/core
creating build/src.linux-aarch64-3.8/numpy/core/src
creating build/src.linux-aarch64-3.8/numpy/core/src/npymath
conv_template:> build/src.linux-aarch64-3.8/numpy/core/src/npymath/npy_math_internal.h
adding 'build/src.linux-aarch64-3.8/numpy/core/src/npymath' to include_dirs.
conv_template:> build/src.linux-aarch64-3.8/numpy/core/src/npymath/ieee754.c
conv_template:> build/src.linux-aarch64-3.8/numpy/core/src/npymath/npy_math_complex.c
None - nothing done with h_files = ['build/src.linux-aarch64-3.8/numpy/core/src/npymath/npy_math_internal.h']
building library "npysort" sources
creating build/src.linux-aarch64-3.8/numpy/core/src/common
conv_template:> build/src.linux-aarch64-3.8/numpy/core/src/common/npy_sort.h
adding 'build/src.linux-aarch64-3.8/numpy/core/src/common' to include_dirs.
creating build/src.linux-aarch64-3.8/numpy/core/src/npysort
conv_template:> build/src.linux-aarch64-3.8/numpy/core/src/npysort/quicksort.c
conv_template:> build/src.linux-aarch64-3.8/numpy/core/src/npysort/mergesort.c
conv_template:> build/src.linux-aarch64-3.8/numpy/core/src/npysort/timsort.c
conv_template:> build/src.linux-aarch64-3.8/numpy/core/src/npysort/heapsort.c
conv_template:> build/src.linux-aarch64-3.8/numpy/core/src/npysort/radixsort.c
conv_template:> build/src.linux-aarch64-3.8/numpy/core/src/common/npy_partition.h
conv_template:> build/src.linux-aarch64-3.8/numpy/core/src/npysort/selection.c
conv_template:> build/src.linux-aarch64-3.8/numpy/core/src/common/npy_binsearch.h
conv_template:> build/src.linux-aarch64-3.8/numpy/core/src/npysort/binsearch.c
None - nothing done with h_files = ['build/src.linux-aarch64-3.8/numpy/core/src/common/npy_sort.h', 'build/src.linux-aarch64-3.8/numpy/core/src/common/npy_partition.h', 'build/src.linux-aarch64-3.8/numpy/core/src/common/npy_binsearch.h']
building extension "numpy.core._dummy" sources
Generating build/src.linux-aarch64-3.8/numpy/core/include/numpy/config.h
_configtest.c:1:10: fatal error: Python.h: No such file or directory
1 | #include <Python.h>
compilation terminated.
failure.
File "<string>", line 1, in <module>
File "/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/setup.py", line 443, in <module>
setup_package()
File "/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/setup.py", line 435, in setup_package
setup(**metadata)
File "/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/numpy/distutils/core.py", line 171, in setup
return old_setup(**new_attr)
File "/home/aliger/.local/lib/python3.8/site-packages/setuptools/__init__.py", line 153, in setup
return distutils.core.setup(**attrs)
File "/usr/lib/python3.8/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/lib/python3.8/distutils/dist.py", line 966, in run_commands
self.run_command(cmd)
File "/usr/lib/python3.8/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "/home/aliger/.local/lib/python3.8/site-packages/wheel/bdist_wheel.py", line 299, in run
self.run_command('build')
File "/usr/lib/python3.8/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/numpy/distutils/command/build.py", line 47, in run
old_build.run(self)
File "/usr/lib/python3.8/distutils/command/build.py", line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/numpy/distutils/command/build_src.py", line 142, in run
self.build_sources()
File "/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/numpy/distutils/command/build_src.py", line 159, in build_sources
self.build_extension_sources(ext)
File "/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/numpy/distutils/command/build_src.py", line 316, in build_extension_sources
sources = self.generate_sources(sources, ext)
File "/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/numpy/distutils/command/build_src.py", line 369, in generate_sources
source = func(extension, build_dir)
File "numpy/core/setup.py", line 430, in generate_config_h
moredefs, ignored = cocache.check_types(config_cmd, ext, build_dir)
File "numpy/core/setup.py", line 49, in check_types
out = check_types(*a, **kw)
File "numpy/core/setup.py", line 286, in check_types
raise SystemError(
SystemError: Cannot compile 'Python.h'. Perhaps you need to install python-dev|python-devel.
ERROR: Failed building wheel for numpy
Running setup.py clean for numpy
command: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/setup.py'"'"'; __file__='"'"'/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' clean --all
Complete output (10 lines):
`setup.py clean` is not supported, use one of the following instead:
- `git clean -xdf` (cleans all files)
- `git clean -Xdf` (cleans all versioned files, doesn't touch
files that aren't checked into the git repo)
Add `--force` to your command to use it anyway if you must (unsupported).
ERROR: Failed cleaning build dir for numpy
Failed to build numpy
Installing collected packages: wheel, setuptools, numpy, Cython
Running setup.py install for numpy: started
Running setup.py install for numpy: finished with status 'error'
command: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/setup.py'"'"'; __file__='"'"'/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-2u6hzoze/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-efabbijr/overlay --compile --install-headers /tmp/pip-build-env-efabbijr/overlay/include/python3.8/numpy
Complete output (312 lines):
Note: if you need reliable uninstall behavior, then install
with pip instead of using `setup.py install`:
- `pip install .` (from a git repo or downloaded source
release)
- `pip install numpy` (last NumPy release on PyPi)
blas_opt_info:
blas_mkl_info:
NOT AVAILABLE
blis_info:
NOT AVAILABLE
openblas_info:
NOT AVAILABLE
NOT AVAILABLE
NOT AVAILABLE
NOT AVAILABLE
atlas_blas_info:
NOT AVAILABLE
accelerate_info:
NOT AVAILABLE
Blas library.
self.calc_info()
blas_info:
NOT AVAILABLE
self.calc_info()
blas_src_info:
NOT AVAILABLE
self.calc_info()
NOT AVAILABLE
lapack_opt_info:
lapack_mkl_info:
NOT AVAILABLE
NOT AVAILABLE
NOT AVAILABLE
flame_info:
NOT AVAILABLE
NOT AVAILABLE
atlas_3_10_info:
NOT AVAILABLE
atlas_threads_info:
NOT AVAILABLE
atlas_info:
NOT AVAILABLE
lapack_info:
NOT AVAILABLE
lapack_src_info:
NOT AVAILABLE
NOT AVAILABLE
warnings.warn(msg)
running install
running build
running config_cc
running config_fc
running build_src
build_src
success!
1 | int exp (void);
1 | int exp (void);
failure.
1 | int exp (void);
1 | int exp (void);
success!
failure.
setup_package()
setup(**metadata)
dist.run_commands()
cmd_obj.run()
File "/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/numpy/distutils/command/install.py", line 62, in run
r = self.setuptools_run()
File "/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/numpy/distutils/command/install.py", line 36, in setuptools_run
return distutils_install.run(self)
File "/usr/lib/python3.8/distutils/command/install.py", line 589, in run
cmd_obj.run()
old_build.run(self)
cmd_obj.run()
raise SystemError(
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/setup.py'"'"'; __file__='"'"'/tmp/pip-install-kax664aj/numpy_466cfb291cfd49caa60b0d851f62ac96/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-2u6hzoze/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-efabbijr/overlay --compile --install-headers /tmp/pip-build-env-efabbijr/overlay/include/python3.8/numpy Check the logs for full command output.
WARNING: Discarding https://files.pythonhosted.org/packages/6e/be/a8ccf9d949a55023cf02438310e068c263ce3dd6bbf31f9229d3db6e551a/scikit-image-0.18.1.tar.gz#sha256=fbb618ca911867bce45574c1639618cdfb5d94e207432b19bc19563d80d2f171 (from https://pypi.org/simple/scikit-image/) (requires-python:>=3.7). Command errored out with exit status 1: /usr/bin/python3 /tmp/pip-standalone-pip-8vojzic3/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-efabbijr/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- wheel 'setuptools<=51.0.0' 'Cython>=0.29.18' 'numpy==1.16.5; python_version=='"'"'3.7'"'"'' 'numpy==1.17.3; python_version=='"'"'3.8'"'"'' 'numpy==1.19.3; python_version=='"'"'3.9'"'"'' 'numpy; python_version>='"'"'3.10'"'"'' Check the logs for full command output.
Using cached scikit-image-0.18.0.tar.gz (36.4 MB)
command: /usr/bin/python3 /tmp/pip-standalone-pip-836pdlr4/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-xrav9odf/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- wheel 'setuptools<=51.0.0' 'Cython>=0.29.18' 'numpy==1.16.5; python_version=='"'"'3.7'"'"'' 'numpy==1.17.3; python_version=='"'"'3.8'"'"'' 'numpy==1.19.3; python_version=='"'"'3.9'"'"'' 'numpy; python_version>='"'"'3.10'"'"''
cwd: None
Collecting wheel
command: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/setup.py'"'"'; __file__='"'"'/tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-ht62ebwt
cwd: /tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/
blas_opt_info:
blas_mkl_info:
NOT AVAILABLE
blis_info:
NOT AVAILABLE
openblas_info:
NOT AVAILABLE
NOT AVAILABLE
NOT AVAILABLE
NOT AVAILABLE
atlas_blas_info:
NOT AVAILABLE
accelerate_info:
NOT AVAILABLE
/tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/numpy/distutils/system_info.py:690: UserWarning:
Blas library.
self.calc_info()
blas_info:
NOT AVAILABLE
self.calc_info()
blas_src_info:
NOT AVAILABLE
self.calc_info()
NOT AVAILABLE
lapack_opt_info:
lapack_mkl_info:
NOT AVAILABLE
NOT AVAILABLE
NOT AVAILABLE
flame_info:
NOT AVAILABLE
NOT AVAILABLE
atlas_3_10_info:
NOT AVAILABLE
atlas_threads_info:
NOT AVAILABLE
atlas_info:
NOT AVAILABLE
lapack_info:
NOT AVAILABLE
/tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/numpy/distutils/system_info.py:1712: UserWarning:
lapack_src_info:
NOT AVAILABLE
NOT AVAILABLE
warnings.warn(msg)
running bdist_wheel
running build
running config_cc
running config_fc
running build_src
build_src
creating build
success!
1 | int exp (void);
1 | int exp (void);
/tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/_configtest.c:6: undefined reference to `exp'
failure.
1 | int exp (void);
1 | int exp (void);
success!
failure.
File "/tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/setup.py", line 443, in <module>
setup_package()
File "/tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/setup.py", line 435, in setup_package
setup(**metadata)
File "/tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/numpy/distutils/core.py", line 171, in setup
dist.run_commands()
cmd_obj.run()
cmd_obj.run()
File "/tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/numpy/distutils/command/build.py", line 47, in run
old_build.run(self)
cmd_obj.run()
File "/tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/numpy/distutils/command/build_src.py", line 142, in run
File "/tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/numpy/distutils/command/build_src.py", line 159, in build_sources
File "/tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/numpy/distutils/command/build_src.py", line 316, in build_extension_sources
File "/tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/numpy/distutils/command/build_src.py", line 369, in generate_sources
raise SystemError(
command: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/setup.py'"'"'; __file__='"'"'/tmp/pip-install-xiniojup/numpy_046229acfcbe414dacc1f2927cae7959/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' clean --all
Once again thank you :)
