안녕하세요?
SDKManager를 통해서 Jetpack4.4를 설치할 때 아래와 같은 문제가 있습니다.
에러로그:
14:50:08 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
14:50:08 SUMMARY: File System and OS - target_image: Install completed successfully.
14:50:08 SUMMARY: CUDA on Host - host: Install completed successfully.
14:50:08 SUMMARY: VisionWorks on Host - host: Install completed successfully.
14:50:08 SUMMARY: VPI on Host - host: Install completed successfully.
14:50:08 SUMMARY: NVIDIA Nsight Graphics - host: Install completed successfully.
14:50:08 SUMMARY: NVIDIA Nsight Systems - host: Install completed successfully.
14:50:13 ERROR: Can not find matching device in recovery mode.
14:50:13 SUMMARY: Device Mode Host Setup in Flash - flash: Install completed successfully.
14:50:18 ERROR: CUDA Cross Compile Package on Host - host: E: Unable to correct problems, you have held broken packages.
14:50:18 ERROR: CUDA Cross Compile Package on Host - host: command terminated with error
14:50:18 SUMMARY: CUDA Cross Compile Package on Host - host: First Error: APT system is broken and requires manual fix
14:50:19 ERROR: Flash Jetson Xavier NX - flash: Board ID(3668) version(301) sku(0003) revision(B.0)
14:50:19 ERROR: Flash Jetson Xavier NX - flash: 1+0 records in
14:50:19 ERROR: Flash Jetson Xavier NX - flash: 1+0 records out
14:50:19 ERROR: Flash Jetson Xavier NX - flash: 4096 bytes (4.1 kB, 4.0 KiB) copied, 9.2044e-05 s, 44.5 MB/s
14:50:43 ERROR: Flash Jetson Xavier NX - flash: Error: Return value 2
14:50:43 ERROR: Flash Jetson Xavier NX - flash: command terminated with error
14:50:43 SUMMARY: Flash Jetson Xavier NX - flash: Installation failed.
14:51:02 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
14:51:02 SUMMARY: File System and OS - target_image: Install completed successfully.
14:51:02 SUMMARY: CUDA on Host - host: Install completed successfully.
14:51:02 SUMMARY: VisionWorks on Host - host: Install completed successfully.
14:51:02 SUMMARY: VPI on Host - host: Install completed successfully.
14:51:02 SUMMARY: NVIDIA Nsight Graphics - host: Install completed successfully.
14:51:02 SUMMARY: NVIDIA Nsight Systems - host: Install completed successfully.
14:51:09 ERROR: Can not find matching device in recovery mode.
14:51:09 SUMMARY: Device Mode Host Setup in Flash - flash: Install completed successfully.
14:51:14 ERROR: CUDA Cross Compile Package on Host - host: E:
14:51:14 ERROR: CUDA Cross Compile Package on Host - host: Unable to correct problems, you have held broken packages.
14:51:14 ERROR: CUDA Cross Compile Package on Host - host: command terminated with error
14:51:14 SUMMARY: CUDA Cross Compile Package on Host - host: First Error: APT system is broken and requires manual fix
14:51:14 ERROR: Flash Jetson Xavier NX - flash: Error: probing the target board failed.
14:51:14 ERROR: Flash Jetson Xavier NX - flash: command terminated with error
14:51:14 SUMMARY: Flash Jetson Xavier NX - flash: Jetson board is in a bad state and cannot be recovered. Please manually put board to recovery mode again and retry.. The Jetson target is in a bad state and cannot be flashed. Please manually put the target into recovery mode and then retry flashing.
위 문제를 어떻게 해결할 수 있을까요?
고맙습니다.
