manthey
#1
I am using LinuxMint 19 which is based on Ubuntu 18.04. Previously I could execute
export LSB_ETC_LSB_RELEASE=/etc/upstream-release/lsb-release
and then run sdkmanager just normally. That is no longer working in version 1.7.0.8846.
How can I run sdkmanager on LinuxMint 19 now?
kayccc
#3
The Linux Mint is not officially supported by SDKM, could you try with Ubuntu directly?
manthey
#4
Mint is based on Ubuntu. But here is the solution.
make a copy of your file: /etc/os-release
which is probably a link to /usr/lib/os-release
Then edit the file like this:
--- /usr/lib/os-release 2018-02-12 19:21:45.000000000 +0100
+++ /usr/lib/os-release.sdkmanager 2021-11-15 10:47:37.818237598 +0100
@@ -1,9 +1,9 @@
NAME="Linux Mint"
VERSION="19 (Tara)"
-ID=linuxmint
+ID=ubuntu
ID_LIKE=ubuntu
PRETTY_NAME="Linux Mint 19"
-VERSION_ID="19"
+VERSION_ID="18.04"
HOME_URL="https://www.linuxmint.com/"
SUPPORT_URL="https://forums.ubuntu.com/"
BUG_REPORT_URL="http://linuxmint-troubleshooting-guide.readthedocs.io/en/latest/
system
closed
#6
