NVIDIA SDK Manager is an all-in-one tool that bundles developer software and
provides an end-to-end development environment setup solution for NVIDIA
SDKs.
But when I launch it nothing happens, the screen wont launch.
and the log file is empty
david@FAS:~$ cd .nvsdkm
david@FAS:~/.nvsdkm$ ls
downloadLogs sdkm-2026-09-16-14-59-51.log sdkm-2026-09-16-15-11-33.log sdkm-2026-09-16-15-23-20.log
replays sdkm-2026-09-16-14-59-59.log sdkm-2026-09-16-15-22-54.log sdkm.db
david@FAS:~/.nvsdkm$ sdkmanager
downloadLogs sdkm-2026-09-16-14-59-51.log sdkm-2026-09-16-15-11-33.log sdkm-2026-09-16-15-23-20.log sdkm.db
replays sdkm-2026-09-16-14-59-59.log sdkm-2026-09-16-15-22-54.log sdkm-2026-09-16-16-02-07.log
david@FAS:~/.nvsdkm$ cat sdkm-2026-09-16-16-02-07.log
An update.. I can download sdkmanager 2.4.0 and it complains there is a later database on my system and it copies it somewhere and installs its own database and v2.4.0 is back and it runs fine.
When 2.4.0 prompts me to allow an upgrade to 2.4.1 and I agree, 2.4.1 wont launch.
So, I just purge 2.4.1 and reinstall 2.4.0 and I am running again.
I do not really need 2.4.1, I am just trying to stay current.
I was hoping 2.4.1 supported super mode on an NX processor… but nope :-(
We will investigate the SDK Manager 2.4.1 launch issue internally.
Regarding Super Mode, support depends on the Jetson platform, JetPack/L4T release, and flashing configuration. Whether SDK Manager provides that flashing configuration is a separate question.
Are you referring specifically to flashing your NX with the Super configuration through SDK Manager?
Please also share the following:
Your exact Jetson NX model and memory size.
Your carrier board model.
The JetPack/L4T version you intend to use.
These details will help us confirm Super Mode support for your configuration.
I have long known that the SDK Manager does not flash the NX SOC into a state where super mode is available. I have seen that later versions of the SDK Managers do in fact flash the nano into a super mode available sate starting with JP 6.2X I think.
And so I flash my NX platforms into a super mode available state with the CLI.
I am using a stock Nvidia jetson orin devkit Model P3766, with a stock 8GB Model P3767 (sometimes 16 GB) NX SOC.
We were flashing 6.2.1 and 6.2.2 but as of today we flash 6.2.3b81.
It is my request and hope to use the SDK Manager with the NX in a production released JP 6.x, but until then it seems I will continue to use the CLI.
I have seen similar behavior with SDK Manager 2.4.1 on Ubuntu 22.04.
In my case, the issue appeared to be related to displaying the GUI under Wayland. As a workaround, I was able to launch the SDK Manager GUI explicitly using X11 with the following command:
