Sdkmanager session expired please login again
I am trying to install older version of 3.3.4 I have ubunut 16.04 as host system. I installed sdk manager however when I start I get the error ‘session expired please log in again’ it is the same error for sdkmanger --cli also, do you know how to fix this issue? I can login on the web browser the login goes through but it doesn’t get reflected in the sdkmanager.
Hi subramanya.nageshrao,
Are you using the devkit or custom board for Jetson Nano?
Do you mean the Jetpack 3.3.4?
It seems the first release for Jetson Nano is Jetpack 4.2 (L4T R32.1)
Do you have any requirement to rollback to JP3.3.4?
I am trying to install jetpack 3.3.4 does it not support nano tx2? It is needed because of old dev sw that controls the hardware and it was built on 16.04 platform. I tried sdkmanager 2.x and 1.9 both gave same error. If I try older version of sdkmanager say 0.9 then I get another error as “TypeError: Cannot read property ‘includes’ of undefined”
Jetpack3.3 does not support Jetson nano…
There is nothing called nano tx2 either. Don’t know what you are asking here.
I was able to install 18.04 JP 4.6 on an older Jetson Nano developer kit. Thank you.
Jetson Nano is supported from Jetpack 4.2 so that JP4.6 can work in your case.
Please refer to Jetson Linux Archive | NVIDIA Developer for all supported L4T release for each modules.
