I want to use the whole jetpack software to flash an image stored on a host ubuntu pc onto a Jetson Xavier.
I downloaded sdkmanager_1.3.0-7105_amd64.deb from the official website then ran the command
sudo apt install ./sdkmanager_1.3.0-7105_amd64.deb
as instructed. The installation of the sdkmanager seems to go through, however, if I then use the command
sdkmanager
nothing happens. The terminal waits for approximately 5 seconds then returns a blank line and nothing shows up.
I tried using sdkmanager --enable-logging -v=1but instead of returning a proper error log I get :
Error: unknown argument '--enable-logging' Error: unknown argument '--v'
As a result I can’t go through with installing the whole jetpack software.
Also it might help anyone coming across this that I tried installing the sdkmanager v0.9.12 linked with JetPack4.3, the sdkmanager command does open the GUI but after inputting my credentials and password, I get No SDK available for your account and it won’t change no matter how many times i restart the sdkmanager (as suggested here No SDK available for your account )
My system:
Ubuntu 18.04.5 LTS
Nvidia Driver Version: 440.95.01
CUDA Version: 10.2
Attempting to install JetPack4.4
