I am trying to use the SDK Manager but when I select my target host (NX) the Linux selection bar is grayed out.
Looking at ~/.nvsdkm/sdkm.log I see:
11:27:00.343 - info:
11:27:00.343 - info: validating release: DRIVE OS 5.1.9.0 PDK
11:27:00.344 - error: Not NVOnline user
11:27:00.344 - warn: No access to release DRIVE OS 5.1.9.0 PDK. Message invalid level3 json path
11:27:00.344 - info:
11:27:00.344 - info: validating release: DRIVE OS 5.1.6.0 PDK
11:27:00.344 - warn: No access to release DRIVE OS 5.1.6.0 PDK. Message invalid level3 json path
11:27:00.344 - info: validating release: DRIVE OS 5.1.6.0 SDK
11:27:00.345 - error: Not NVOnline user
11:27:00.345 - warn: No access to release DRIVE OS 5.1.6.0 SDK. Message invalid level3 json path
11:27:00.345 - info:
11:27:00.345 - info: validating release: DRIVE OS 5.1.3.0 PDK
11:27:00.345 - warn: No access to release DRIVE OS 5.1.3.0 PDK. Message invalid level3 json path
11:27:00.346 - info: validating release: DRIVE OS 5.1.3.0 SDK
11:27:00.346 - error: Not NVOnline user
11:27:00.346 - warn: No access to release DRIVE OS 5.1.3.0 SDK. Message invalid level3 json path
11:27:00.346 - info: validating release: DRIVE OS 5.0.13.2 (with DRIVE AV)
11:27:00.346 - warn: No access to release DRIVE OS 5.0.13.2 (with DRIVE AV). Message invalid level3 json path
11:27:00.360 - info: Validate l3 url successfully
11:27:00.360 - info: validating release: JetPack 3.3.3
11:27:00.741 - info: Validate l3 url successfully
11:27:00.741 - info: validating release: JetPack 3.3.2
11:27:01.089 - info: Validate l3 url successfully
11:27:01.090 - info: validating release: JetPack 3.3.1
11:27:01.090 - info: Validate l3 url successfully
11:27:01.091 - info:
11:27:01.091 - info: validating release: JetPack 4.2.3
11:27:01.091 - info: Validate l3 url successfully
11:27:01.092 - info:
11:27:01.092 - info: validating release: JetPack 4.2.2
11:27:01.092 - info: Validate l3 url successfully
11:27:01.093 - info:
11:27:01.093 - info: validating release: JetPack 4.2.1
11:27:01.629 - info: Validate l3 url successfully
11:27:01.630 - info: validating release: JetPack 4.2
11:27:01.876 - info: Validate l3 url successfully
11:27:01.877 - info: Event: Login Progress: Loading and processing available products…
11:27:01.883 - info:
11:27:01.883 - info: validating release: DeepStream
11:27:02.130 - info: Validate l3 url successfully
11:27:02.131 - info: validating release: DeepStream
11:27:02.391 - info: Validate l3 url successfully
11:27:02.392 - info:
11:27:02.392 - info: validating release: DeepStream
11:27:02.667 - info: Validate l3 url successfully
11:27:02.667 - info: validating release: DeepStream
11:27:02.911 - info: Validate l3 url successfully
11:27:03.164 - info: Selecting Jetson product
11:27:03.167 - info: step1 load in ms: 6470.279999999999
11:27:03.168 - info: Web server configuration build version 1003D584J23C is set
11:27:03.213 - info: Checking for update with mainRepoURL: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
11:27:03.407 - info: sdkml1_repo.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json has been downloaded to /home/pisymbol/.nvsdkm/dist successfully.
11:27:03.963 - info: sdkml2_sdkmanager_linux_deb.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/SDKMANAGER/Linux/sdkml2_sdkmanager_linux_deb.json has been downloaded to /home/pisymbol/.nvsdkm/dist successfully.
11:27:03.966 - info: packageJson: /opt/nvidia/sdkmanager/resources/app/package.json
11:27:03.977 - info: [updater] no SDK Manager client update available.
11:27:06.870 - info: Selecting Jetson product
11:27:47.248 - info: == second-instance == /opt/nvidia/sdkmanager/sdkmanager /snapshot/main/headless.bundle.js
11:27:47.959 - info: cleaning up engine
11:27:47.959 - info: installManager cleanup
11:27:47.960 - info: cleanning up the downloader and worker
11:27:47.960 - info: [Worker] destroying
11:27:47.963 - info: The overall duration (Download + Install) is 0.000s
I did successfully login via external browser link. But I do see those error messages which are strange. Is there something wrong with my account?
