The meme 3.5.3 application, available from http://meme.sdsc.edu/meme/intro.html fails to compile the source file init.c, with error message:
usculus403-6:src$ pgcc -DHAVE_CONFIG_H -I. -I.. -I./include -I./libadd -DUNIX -D__USE_FIXE_PROTOTYPES -O -c init.c
PGC-S-0204-Actual parameters too long for DO_STANDARD_COMMAND_LINE (init.c: 237)
PGC-F-0008-Error limit exceeded (init.c)
PGC/x86-64 Linux/x86-64 6.1-4: compilation aborted
The application is configured with
CC=pgcc ./configure --enable-opt --disable-server
The file compiles w/o problems with gcc. Looks like a PGI cpp problem to mee. Anybody who have manage to compile and run meme with pgi compilers ? Thanks in advance for any feedback.[/code][/url]
