Secondary classifier not working in nvstreamdemux src_1 branch
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.3
• TensorRT Version 8.5.3
• NVIDIA GPU Driver Version (valid for GPU only) 565.57.01
• Issue Type( questions, new requirements, bugs) bugs
Hi there,
I’m testing DeepStream pipelines where the detector (primary mode) runs in the Triton inference server and the car make/brand classifier (secondary mode) runs in one of the output branches after the nvstreamdemux plug-in. Following shows what the pipeline looks like.
The pipeline works if the car make/brand classifier is in the first (src_0) branch of the demuxer but fails if it is in the second (src_1) branch. If I have understood it correctly, the demuxer separates the meta-data buffers into separate branches/streams so the classifier should work in both of the branches, right? Is it a problem with the tracker parameters, possibly? The following is how the tracker is set up:
BaseConfig:
  minDetectorConfidence: 0.5   # If the confidence of a detector bbox is lower than this, then it won't be considered for tracking
TargetManagement:
  enableBboxUnClipping: 1   # In case the bbox is likely to be clipped by image border, unclip bbox
  maxTargetsPerStream: 150  # Max number of targets to track per stream. Recommended to set >10. Note: this value should account for the targets being tracked in shadow mode as well. Max value depends on the GPU memory capacity
  # [Creation & Termination Policy]
  minIouDiff4NewTarget: 0.5   # If the IOU between the newly detected object and any of the existing targets is higher than this threshold, this newly detected object will be discarded.
  minTrackerConfidence: 0.2   # If the confidence of an object tracker is lower than this on the fly, then it will be tracked in shadow mode. Valid Range: [0.0, 1.0]
  probationAge: 5 # If the target's age exceeds this, the target will be considered to be valid.
  maxShadowTrackingAge: 30  # Max length of shadow tracking. If the shadowTrackingAge exceeds this limit, the tracker will be terminated.
  earlyTerminationAge: 1   # If the shadowTrackingAge reaches this threshold while in TENTATIVE period, the target will be terminated prematurely.
TrajectoryManagement:
  useUniqueID: 1   # Use 64-bit long Unique ID when assignining tracker ID. Default is [true]
DataAssociator:
  dataAssociatorType: 0 # the type of data associator among { DEFAULT= 0 }
  associationMatcherType: 0 # the type of matching algorithm among { GREEDY=0, GLOBAL=1 }
  checkClassMatch: 1  # If checked, only the same-class objects are associated with each other. Default: true
  # [Association Metric: Thresholds for valid candidates]
  minMatchingScore4Overall: 0.0   # Min total score
  minMatchingScore4SizeSimilarity: 0.6  # Min bbox size similarity score
  minMatchingScore4Iou: 0.0       # Min IOU score
  minMatchingScore4VisualSimilarity: 0.7  # Min visual similarity score
  # [Association Metric: Weights]
  matchingScoreWeight4VisualSimilarity: 0.6  # Weight for the visual similarity (in terms of correlation response ratio)
  matchingScoreWeight4SizeSimilarity: 0.0    # Weight for the Size-similarity score
  matchingScoreWeight4Iou: 0.4   # Weight for the IOU score
StateEstimator:
  stateEstimatorType: 1  # the type of state estimator among { DUMMY=0, SIMPLE=1, REGULAR=2 }
  # [Dynamics Modeling]
  processNoiseVar4Loc: 2.0    # Process noise variance for bbox center
  processNoiseVar4Size: 1.0   # Process noise variance for bbox size
  processNoiseVar4Vel: 0.1    # Process noise variance for velocity
  measurementNoiseVar4Detector: 4.0    # Measurement noise variance for detector's detection
  measurementNoiseVar4Tracker: 16.0    # Measurement noise variance for tracker's localization
VisualTracker:
  visualTrackerType: 1 # the type of visual tracker among { DUMMY=0, NvDCF=1 }
  # [NvDCF: Feature Extraction]
  useColorNames: 1     # Use ColorNames feature
  useHog: 1            # Use Histogram-of-Oriented-Gradient (HOG) feature
  featureImgSizeLevel: 2  # Size of a feature image. Valid range: {1, 2, 3, 4, 5}, from the smallest to the largest
  featureFocusOffsetFactor_y: -0.2 # The offset for the center of hanning window relative to the feature height. The center of hanning window would move by (featureFocusOffsetFactor_y*featureMatSize.height) in vertical direction
  # [NvDCF: Correlation Filter]
  filterLr: 0.075 # learning rate for DCF filter in exponential moving average. Valid Range: [0.0, 1.0]
  filterChannelWeightsLr: 0.1 # learning rate for the channel weights among feature channels. Valid Range: [0.0, 1.0]
  gaussianSigma: 0.75 # Standard deviation for Gaussian for desired response when creating DCF filter [pixels]
Classifier in Demuxer src_0
If the secondary inference is in the demux src_0 branch, then everything works as expected and we can see the car make/brand in the sink. Following is what the pipeline looks like
The output looks like this
This is how the pipeline was launched:
gst-launch-1.0 -e \
nvstreammux name=mux width=1280 height=720 batch-size=2 ! \
nvinferserver config-file-path=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app-triton/config_infer_plan_engine_primary.txt batch-size=2 ! \
nvtracker tracker-width=640 tracker-height=480 ll-config-file=config_tracker_NvDCF_perf.yml ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so ! \
nvstreamdemux name=demux \
nvurisrcbin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 ! queue ! mux.sink_0 \
nvurisrcbin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 ! queue ! mux.sink_1 \
demux.src_0 ! queue ! nvinfer config-file-path=dstest2_sgie2_config.txt ! nvdsosd ! nvvideoconvert ! nveglglessink \
demux.src_1 ! queue ! nvdsosd ! nvvideoconvert ! nveglglessink
Classifier in Demuxer src_1
If the secondary inference is in the demux src_1 branch, then I get the following warning message:
nvinfer gstnvinfer.cpp:1728:gst_nvinfer_process_objects:<nvinfer0> Source info not found for source 1. Maybe the GST_NVEVENT_PAD_ADDED event was never generated for the source.
And the output from the pipeline is as follows
** How to Reproduce the Results **
The exact steps to reproduce the results can be found in GitHub, this is the link gstreamer-examples/deepstream-examples/deepstream-hybrid at main · JarnoRalli/gstreamer-examples · GitHub
Cheers,
Jarno
Yes.
No. I have tried to delete the tracker and replace the nvinferserver with nvinfer, but the problem still persisted. We’ll invetigate this issue ASAP. Thanks
Hi @jarno1, after the nvstreamdemux plugin, you should re-batched the stream with the nvstreammux again in the pipeline. You can refer to the pipeline like below.
gst-launch-1.0 -e nvstreammux name=mux width=1920 height=1080 batch-size=2 ! nvinfer config-file-path=dstest2_pgie_config.txt batch-size=2 ! nvtracker tracker-width=640 tracker-height=480 ll-config-file=config_tracker_NvDCF_perf.yml ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so ! nvstreamdemux name=demux nvurisrcbin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 ! queue ! mux.sink_0 nvurisrcbin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 ! queue ! mux.sink_1 demux.src_1 ! mux1.sink_0 nvstreammux name=mux1 width=1920 height=1080 batch-size=1  ! queue ! nvinfer config-file-path=dstest2_sgie2_config.txt ! nvdsosd ! nvvideoconvert ! nveglglessink demux.src_0 ! mux2.sink_0 nvstreammux name=mux2 width=1920 height=1080 batch-size=1 ! queue ! nvdsosd ! nvvideoconvert ! nveglglessink
You can also refer to our deepstream_parallel_inference_app.
Thank you very much @yuweiw. I tested the pipelines with the nvstreammux in both of the outputs, using nvinferserver for the primary inference and nvinfer for the secondary inference and everything worked as expected. I’m not sure if it’s explicitly stated in the nvstreamdemux documentation and there needs to be a nvstreammux in the output if inference is done in the branch in question. Might be a good idea to add an example. In any case, thank you very much for your help!
