Thanks, could you also attach a testing video like the demo shared in May 7.
Hi @AastaLLL ,
I have shared the test videos in private message. Please check and revert back at the earliest.
Thanks for your sharing.
We are checking this internally. Will update more soon.
Would you mind to share the emotion model as well as its label file with us?
Since we only have the gender/age classifier, it’s hard to tell the output is updated or not.
(Since the expected class remains the same)
Hi @AastaLLL,
I have uploaded the emotion model and related files with you in the earlier dropbox link that I provided in your personal inbox.
Please revert back if there are any additional requirements
Will get back to you later.
Confirmed that we can see the similar issue as you mentioned.
We are checking this in details.
Sorry for keeping you waiting.
Confirmed that your use case can work with tracker ON + secondary-reinfer-interval=0
in the classifier configure file.
Attached the configure for your reference.
ds_pipeline_topic_176852.txt (5.4 KB)
config_infer_primary.txt (2.0 KB)
config_infer_secondary.txt (3.4 KB)
