**• Hardware Platform (Jetson / GPU) : dGPU
**• DeepStream Version : 6.0.1
**• JetPack Version (valid for Jetson only) : None
**• TensorRT Version : 8.0.1
**• NVIDIA GPU Driver Version (valid for GPU only) : 495.29.05
**• Issue Type( questions, new requirements, bugs) : questions
**• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) : None
**• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) : None
I want to implement secondary-inference and metadata-attaching using IInferCustomProcessor(nvinferserver),
but I can not access to ObjectMeta in inferenceDone().
I checked nvdsinferserver_custom_process.cpp but couldn’t figure out how.
I found OPTION_NVDS_OBJ_META_LIST in the header but
inOptions->hasValue(OPTION_NVDS_OBJ_META_LIST)
returns false in my experiment.
