Secondary model which is a mask classifier outputs first entry in label.txt file
In deepstream app primary model is peoplenet and after detecting face, applying on it secondary model to classify the mask on face. But result i am getting always first entry of the label.txt file. I am not getting the reason. tlt model is working fine on new testing images and after converting it to etlt, i added it as secondary model then having result issues.
• DeepStream Version
• TensorRT Version
Hey, can you share your configs with us.
And always keep in mind to share your setup with us.
For future reference (since I faced a similar issue for a long time), the problem that I did was that the label file was like this:
label1
label2
label3
Instead, for secondary classifiers it need to be like this :
label1;label2;label3
Hi,I have similar issue,but change label still exist same error
In my case, there was formatting issue with training data on which model was trained. You can also check the training/ validation text/csv data are in proper format and then training is running properly. see if this work for you.
I will try it,thanks
by the way, what is your deepstream sdk version?
