Secure Boot image creation
Is there any way to sign the images externally instead of passing the pkc_keyfile ./flash.sh -u <pkc_keyfile> …,
during the flash command. I would like to avoid putting the pkc_keyfile on the flash compute.
Thanks,
Tanya
hello grs.tanya,
please refer to mass fuse documentation, which should be available of Jetpack release image. the file path looks like… $OUT/Linux_for_Tegra/bootloader/README_Massfuse.txt
please refer to the steps as mentioned in [Building the Massfuse Blob with OFFLINE method], you should use the massfuse blob for deployment.
Thank you
