Hi @JerryChang
These are the flash logs kindly guide me which files do I have to sign and encrypt? and kindly guide me where are they located in /Linux_for_tegra/
and where to put them after signing and encrypting.
cowlar@cowlar-PC:~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra$ sudo ./flash.sh jetson-agx-xavier-devkit mmcblk0p1
[sudo] password for cowlar:
# L4T BSP Information:
# R32 , REVISION: 5.1
# Target Board Information:
# Name: jetson-agx-xavier-devkit, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying soft_fuses(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
[ 0.0060 ] Generating RCM messages
[ 0.0076 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0084 ] Header already present for /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0146 ]
[ 0.0162 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0171 ] Assuming zero filled SBK key
[ 0.0194 ]
[ 0.0207 ] tegrasign_v2 --key None --file /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[ 0.0217 ] Assuming zero filled SBK key
[ 0.0224 ]
[ 0.0234 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0294 ]
[ 0.0315 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0347 ]
[ 0.0361 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.0372 ] RCM 0 is saved as rcm_0.rcm
[ 0.0433 ] RCM 1 is saved as rcm_1.rcm
[ 0.0433 ] RCM 2 is saved as rcm_2.rcm
[ 0.0433 ] List of rcm files are saved in rcm_list.xml
[ 0.0433 ]
[ 0.0434 ] Signing RCM messages
[ 0.0447 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.0458 ] Assuming zero filled SBK key
[ 0.0466 ]
[ 0.0466 ] Copying signature to RCM mesages
[ 0.0477 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0496 ]
[ 0.0497 ] Boot Rom communication
[ 0.0510 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0522 ] RCM version 0X190001
[ 0.1860 ] Boot Rom communication completed
[ 1.2026 ]
[ 2.2054 ] tegrarcm_v2 --isapplet
[ 2.2072 ] Applet version 01.00.0000
[ 2.3892 ]
[ 2.3915 ] tegrarcm_v2 --ismb2
[ 2.6052 ]
[ 2.6072 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 2.6089 ]
[ 2.6106 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 2.6121 ] adding BCH for nvtboot_applet_t194.bin
[ 2.6182 ]
[ 2.6207 ] tegrasign_v2 --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.6222 ] Assuming zero filled SBK key
[ 2.6227 ]
[ 2.6244 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 2.6272 ]
[ 2.6282 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.6290 ] Applet version 01.00.0000
[ 2.8214 ] Sending mb2
[ 2.8216 ] [................................................] 100%
[ 2.8376 ]
[ 2.8397 ] tegrarcm_v2 --boot recovery
[ 2.8414 ] Applet version 01.00.0000
[ 3.0378 ]
[ 4.0409 ] tegrarcm_v2 --isapplet
[ 4.2212 ]
[ 4.2233 ] tegrarcm_v2 --ismb2
[ 4.2247 ] MB2 Applet version 01.00.0000
[ 4.4291 ]
[ 4.4309 ] tegrarcm_v2 --ismb2
[ 4.4323 ] MB2 Applet version 01.00.0000
[ 4.6371 ]
[ 4.6389 ] Retrieving board information
[ 4.6408 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 4.6424 ] MB2 Applet version 01.00.0000
[ 4.8535 ] Saved platform info in chip_info.bin
[ 4.8592 ] Chip minor revision: 2
[ 4.8596 ] Bootrom revision: 0xf
[ 4.8599 ] Ram code: 0x2
[ 4.8601 ] Chip sku: 0xd0
[ 4.8604 ] Chip Sample: non es
[ 4.8605 ]
[ 4.8610 ] Retrieving EEPROM data
[ 4.8610 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/cvm.bin
[ 4.8626 ] MB2 Applet version 01.00.0000
[ 5.0656 ] Saved platform info in /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/cvm.bin
[ 5.1021 ]
[ 5.1023 ] Rebooting to recovery mode
[ 5.1043 ] tegrarcm_v2 --ismb2
[ 5.1058 ] MB2 Applet version 01.00.0000
[ 5.3040 ]
[ 5.3041 ] Rebooting to recovery mode
[ 5.3059 ] tegrarcm_v2 --reboot recovery
[ 5.3073 ] MB2 Applet version 01.00.0000
[ 5.5509 ]
Board ID(2888) version(400) sku(0004) revision(L.0)
Copy /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb to /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb.rec
copying bctfile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying bctfile1(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying uphy_config(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying minratchet_config(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg)... done.
copying device_config(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying misc_cold_boot_config(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying gpioint_config(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
copying pmic_config(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
copying pmc_config(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying prod_config(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying scr_config(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying scr_cold_boot_config(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying bootrom_config(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying dev_params(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
Existing bootloader(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
populating kernel to rootfs... done.
/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs/boot/Image
version 1.0.0
[ 0.0046 ] Generating signature
[ 0.0055 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0062 ] Assuming zero filled SBK key
[ 0.0064 ]
[ 0.0066 ] header_magic: 5614
[ 0.0075 ] tegrahost_v2 --chip 0x19 --align 1_Image
[ 0.0083 ]
[ 0.0092 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_Image zerosbk
[ 0.0099 ] adding BCH for 1_Image
[ 0.8835 ]
[ 0.8857 ] tegrasign_v2 --key --list 1_Image_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.8866 ] Assuming zero filled SBK key
[ 0.9309 ]
[ 0.9324 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
[ 1.4616 ]
[ 1.4986 ] Signed file: /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/Image_sigheader.encrypt
l4t_sign_image.sh: Generate header for Image_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0x20bf808 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
l4t_sign_image.sh: the sign header is saved at /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs/boot/Image.sig
done.
populating initrd to rootfs... done.
/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs/boot/initrd
version 1.0.0
[ 0.0064 ]
[ 0.0066 ] header_magic: 1f8b0800
[ 0.0075 ] tegrahost_v2 --chip 0x19 --align 1_initrd
[ 0.0083 ]
[ 0.0092 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_initrd zerosbk
[ 0.0100 ] adding BCH for 1_initrd
[ 0.1997 ]
[ 0.2018 ] tegrasign_v2 --key --list 1_initrd_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.2027 ] Assuming zero filled SBK key
[ 0.2118 ]
[ 0.2133 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_initrd_sigheader.encrypt 1_initrd_sigheader.hash zerosbk
[ 0.3120 ]
[ 0.3209 ] Signed file: /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/initrd_sigheader.encrypt
l4t_sign_image.sh: Generate header for initrd_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0x6e6ce8 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for initrd_sigheader.encrypt
l4t_sign_image.sh: the sign header is saved at /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs/boot/initrd.sig
done.
populating /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb to rootfs... done.
Making Boot image... done.
/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign boot.img
version 1.0.0
[ 0.0005 ] Generating signature
[ 0.0014 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0023 ] Assuming zero filled SBK key
[ 0.0024 ]
[ 0.0026 ] header_magic: 414e4452
[ 0.0036 ] tegrahost_v2 --chip 0x19 --align 1_boot.img
[ 0.0044 ]
[ 0.0053 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_boot.img zerosbk
[ 0.0062 ] adding BCH for 1_boot.img
[ 1.0681 ]
[ 1.0703 ] tegrasign_v2 --key --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 1.0713 ] Assuming zero filled SBK key
[ 1.1193 ]
[ 1.1209 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[ 1.7638 ]
[ 1.8076 ] Signed file: /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x19: add 0x27a7800 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra
30402 blocks
_BASE_KERNEL_VERSION=4.9.201-tegra
~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/ramdisk_tmp/lib ~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra
65752 blocks
Making Recovery image...
copying recdtbfile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000189866 s, 105 kB/s
Existing sosfile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb)... done.
Existing scefile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing drameccfile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
Existing badpagefile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/badpage.bin) reused.
Existing wb0boot(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign kernel_tegra194-p2888-0001-p2822-0000.dtb
version 1.0.0
[ 0.0006 ] Generating signature
[ 0.0016 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0024 ]
[ 0.0027 ] header_magic: d00dfeed
[ 0.0035 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0043 ]
[ 0.0051 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_kernel_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 0.0060 ] adding BCH for 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0137 ]
[ 0.0154 ] tegrasign_v2 --key --list 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0162 ] Assuming zero filled SBK key
[ 0.0167 ]
[ 0.0178 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 0.0227 ]
[ 0.0233 ] Signed file: /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: chip 0x19: add 0x45209 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the sign header is saved at kernel_tegra194-p2888-0001-p2822-0000.dtb.sig
done.
version 1.0.0
[ 0.0024 ] Assuming zero filled SBK key
[ 0.0026 ]
[ 0.0028 ] header_magic: d00dfeed
[ 0.0040 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0049 ]
[ 0.0057 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_kernel_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 0.0064 ] adding BCH for 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0144 ]
[ 0.0163 ] tegrasign_v2 --key --list 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0175 ] Assuming zero filled SBK key
[ 0.0184 ]
[ 0.0197 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 0.0245 ]
[ 0.0251 ] Signed file: /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
done.
Making system.img...
populating rootfs from /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs ... done.
populating /boot/extlinux/extlinux.conf ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Existing tbcfile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
copying cfgfile(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml... done.
Existing flasher(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0x9190000 --applet mb1_t194_prod.bin --cmd "flash; reboot" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb"
saving flash command in /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0017 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0025 ] Assuming zero filled SBK key
[ 0.0049 ]
[ 0.0050 ] Generating RCM messages
[ 0.0065 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.0073 ] Header already present for mb1_t194_prod.bin
[ 0.0140 ]
[ 0.0152 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0163 ]
[ 0.0175 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[ 0.0185 ] Assuming zero filled SBK key
[ 0.0192 ]
[ 0.0204 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 0.0253 ]
[ 0.0273 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.0307 ]
[ 0.0321 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.0332 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0337 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0337 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0337 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0337 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0337 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0338 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0338 ] FwIndex: 8, MinRatchetLevel: 0
[ 0.0338 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0338 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0338 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0338 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0338 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0338 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0338 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0339 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0339 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0339 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0339 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0339 ]
[ 0.0354 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.0366 ] RCM 0 is saved as rcm_0.rcm
[ 0.0419 ] RCM 1 is saved as rcm_1.rcm
[ 0.0419 ] RCM 2 is saved as rcm_2.rcm
[ 0.0420 ] List of rcm files are saved in rcm_list.xml
[ 0.0420 ]
[ 0.0420 ] Signing RCM messages
[ 0.0434 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.0445 ] Assuming zero filled SBK key
[ 0.0453 ]
[ 0.0454 ] Copying signature to RCM mesages
[ 0.0469 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0493 ]
[ 0.0494 ] Parsing partition layout
[ 0.0514 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0548 ]
[ 0.0549 ] Creating list of images to be signed
[ 0.0562 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 0.0610 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.0619 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.0626 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.0669 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.0676 ] adding BCH for spe_t194.bin
[ 0.0746 ] adding BCH for spe_t194.bin
[ 0.0777 ] adding BCH for nvtboot_t194.bin
[ 0.0810 ] adding BCH for nvtboot_t194.bin
[ 0.0855 ] Header already present for preboot_c10_prod_cr.bin
[ 0.0905 ] Header already present for preboot_c10_prod_cr.bin
[ 0.0909 ] Header already present for mce_c10_prod_cr.bin
[ 0.0916 ] Header already present for mce_c10_prod_cr.bin
[ 0.0935 ] adding BCH for mts_c10_prod_cr.bin
[ 0.1040 ] adding BCH for mts_c10_prod_cr.bin
[ 0.1935 ] adding BCH for cboot_t194.bin
[ 0.2804 ] adding BCH for cboot_t194.bin
[ 0.2916 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 0.3030 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 0.3103 ] adding BCH for tos-trusty_t194.img
[ 0.3188 ] adding BCH for tos-trusty_t194.img
[ 0.3289 ] adding BCH for eks.img
[ 0.3417 ] adding BCH for eks.img
[ 0.3419 ] adding BCH for bpmp_t194.bin
[ 0.3444 ] adding BCH for bpmp_t194.bin
[ 0.3673 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[ 0.3944 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[ 0.4154 ] adding BCH for camera-rtcpu-rce.img
[ 0.4383 ] adding BCH for camera-rtcpu-rce.img
[ 0.4457 ] adding BCH for adsp-fw.bin
[ 0.4537 ] adding BCH for adsp-fw.bin
[ 0.4558 ] Header already present for warmboot_t194_prod.bin
[ 0.4584 ] Header already present for warmboot_t194_prod.bin
[ 0.4593 ] adding BCH for recovery.img
[ 0.5686 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb.rec
[ 1.8379 ] adding BCH for boot.img
[ 1.8718 ] adding BCH for boot.img
[ 2.9432 ] adding BCH for kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 4.1082 ] adding BCH for kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 4.1285 ]
[ 4.1286 ] Filling MB1 storage info
[ 4.1286 ] Generating br-bct
[ 4.1301 ] Performing cfg overlay
[ 4.1301 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 4.1304 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1.cfg
[ 4.2034 ]
[ 4.2036 ] Updating dev and MSS params in BR BCT
[ 4.2037 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 4.2710 ]
[ 4.2711 ] Updating bl info
[ 4.2722 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 4.2745 ]
[ 4.2745 ] Generating signatures
[ 4.2755 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 4.2764 ] Assuming zero filled SBK key
[ 4.5571 ]
[ 4.5573 ] Generating br-bct
[ 4.5591 ] Performing cfg overlay
[ 4.5591 ] ['/home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1.cfg']
[ 4.5591 ] Updating dev and MSS params in BR BCT
[ 4.5592 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 4.6265 ]
[ 4.6266 ] Updating bl info
[ 4.6279 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 4.6311 ]
[ 4.6312 ] Updating smd info
[ 4.6322 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 4.6335 ]
[ 4.6336 ] Updating Odmdata
[ 4.6346 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[ 4.6357 ]
[ 4.6358 ] Get Signed section of bct
[ 4.6367 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 4.6377 ]
[ 4.6387 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 4.6395 ] Assuming zero filled SBK key
[ 4.6398 ]
[ 4.6398 ] Updating BCT with signature
[ 4.6408 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 4.6421 ]
[ 4.6422 ] Generating coldboot mb1-bct
[ 4.6440 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.6451 ] MB1-BCT version: 0x1
[ 4.6455 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 4.6462 ] Added Platform Config 0 data with size :- 3008
[ 4.6485 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 4.6490 ] Added Platform Config 1 data with size :- 19640
[ 4.6680 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 4.6685 ] Added Platform Config 2 data with size :- 24
[ 4.6688 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 4.6693 ] Added Platform Config 4 data with size :- 348
[ 4.6696 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 4.6702 ] Added Platform Config 3 data with size :- 92
[ 4.6702 ]
[ 4.6702 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 4.6702 ] Added Platform Config 5 data with size :- 56
[ 4.6702 ]
[ 4.6702 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 4.6702 ] Added Platform Config 7 data with size :- 392
[ 4.6702 ]
[ 4.6702 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 4.6702 ] Added Platform Config 8 data with size :- 12
[ 4.6703 ]
[ 4.6703 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.6703 ] Added Platform Config 9 data with size :- 32
[ 4.6703 ]
[ 4.6704 ] Updating mb1-bct with firmware information
[ 4.6714 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 4.6722 ] MB1-BCT version: 0x1
[ 4.6726 ]
[ 4.6726 ] Updating mb1-bct with storage information
[ 4.6736 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 4.6745 ] MB1-BCT version: 0x1
[ 4.6750 ]
[ 4.6750 ] Updating mb1-bct with ratchet information
[ 4.6763 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 4.6775 ] MB1-BCT version: 0x1
[ 4.6778 ] FwIndex: 1, MinRatchetLevel: 0
[ 4.6779 ] FwIndex: 2, MinRatchetLevel: 0
[ 4.6780 ] FwIndex: 3, MinRatchetLevel: 0
[ 4.6780 ] FwIndex: 4, MinRatchetLevel: 0
[ 4.6780 ] FwIndex: 5, MinRatchetLevel: 0
[ 4.6780 ] FwIndex: 6, MinRatchetLevel: 0
[ 4.6780 ] FwIndex: 7, MinRatchetLevel: 0
[ 4.6780 ] FwIndex: 8, MinRatchetLevel: 0
[ 4.6780 ] FwIndex: 11, MinRatchetLevel: 0
[ 4.6780 ] FwIndex: 12, MinRatchetLevel: 0
[ 4.6780 ] FwIndex: 13, MinRatchetLevel: 0
[ 4.6780 ] FwIndex: 14, MinRatchetLevel: 0
[ 4.6781 ] FwIndex: 15, MinRatchetLevel: 0
[ 4.6781 ] FwIndex: 16, MinRatchetLevel: 0
[ 4.6781 ] FwIndex: 17, MinRatchetLevel: 0
[ 4.6781 ] FwIndex: 18, MinRatchetLevel: 0
[ 4.6781 ] FwIndex: 19, MinRatchetLevel: 0
[ 4.6781 ] FwIndex: 30, MinRatchetLevel: 0
[ 4.6781 ] FwIndex: 31, MinRatchetLevel: 0
[ 4.6781 ]
[ 4.6789 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 4.6800 ]
[ 4.6811 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 4.6820 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[ 4.6833 ]
[ 4.6844 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.6853 ] Assuming zero filled SBK key
[ 4.6856 ]
[ 4.6868 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 4.6888 ]
[ 4.6889 ] Generating recovery mb1-bct
[ 4.6901 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.6909 ] MB1-BCT version: 0x1
[ 4.6912 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 4.6919 ] Added Platform Config 0 data with size :- 3008
[ 4.6939 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 4.6944 ] Added Platform Config 1 data with size :- 19640
[ 4.7124 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 4.7129 ] Added Platform Config 2 data with size :- 24
[ 4.7132 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 4.7137 ] Added Platform Config 4 data with size :- 348
[ 4.7139 ]
[ 4.7139 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 4.7139 ] Added Platform Config 3 data with size :- 92
[ 4.7140 ]
[ 4.7140 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 4.7140 ] Added Platform Config 5 data with size :- 56
[ 4.7140 ]
[ 4.7140 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 4.7140 ] Added Platform Config 7 data with size :- 392
[ 4.7140 ]
[ 4.7140 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 4.7140 ] Added Platform Config 8 data with size :- 12
[ 4.7140 ]
[ 4.7140 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.7141 ] Added Platform Config 9 data with size :- 32
[ 4.7141 ]
[ 4.7141 ] Updating mb1-bct with firmware information
[ 4.7153 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 4.7162 ] MB1-BCT version: 0x1
[ 4.7166 ]
[ 4.7166 ] Updating mb1-bct with storage information
[ 4.7176 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 4.7185 ] MB1-BCT version: 0x1
[ 4.7190 ]
[ 4.7191 ] Updating mb1-bct with ratchet information
[ 4.7201 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 4.7212 ] MB1-BCT version: 0x1
[ 4.7215 ] FwIndex: 1, MinRatchetLevel: 0
[ 4.7216 ] FwIndex: 2, MinRatchetLevel: 0
[ 4.7216 ] FwIndex: 3, MinRatchetLevel: 0
[ 4.7216 ] FwIndex: 4, MinRatchetLevel: 0
[ 4.7216 ] FwIndex: 5, MinRatchetLevel: 0
[ 4.7217 ] FwIndex: 6, MinRatchetLevel: 0
[ 4.7217 ] FwIndex: 7, MinRatchetLevel: 0
[ 4.7217 ] FwIndex: 8, MinRatchetLevel: 0
[ 4.7217 ] FwIndex: 11, MinRatchetLevel: 0
[ 4.7217 ] FwIndex: 12, MinRatchetLevel: 0
[ 4.7217 ] FwIndex: 13, MinRatchetLevel: 0
[ 4.7217 ] FwIndex: 14, MinRatchetLevel: 0
[ 4.7217 ] FwIndex: 15, MinRatchetLevel: 0
[ 4.7217 ] FwIndex: 16, MinRatchetLevel: 0
[ 4.7217 ] FwIndex: 17, MinRatchetLevel: 0
[ 4.7217 ] FwIndex: 18, MinRatchetLevel: 0
[ 4.7217 ] FwIndex: 19, MinRatchetLevel: 0
[ 4.7217 ] FwIndex: 30, MinRatchetLevel: 0
[ 4.7217 ] FwIndex: 31, MinRatchetLevel: 0
[ 4.7218 ]
[ 4.7226 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 4.7234 ]
[ 4.7245 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1.bct zerosbk
[ 4.7254 ] adding BCH for mb1_bct_MB1.bct
[ 4.7264 ]
[ 4.7277 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.7288 ] Assuming zero filled SBK key
[ 4.7291 ]
[ 4.7302 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 4.7319 ]
[ 4.7321 ] Generating coldboot mem-bct
[ 4.7332 ] tegrabct_v2 --chip 0x19 0 --sdram /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1.cfg --membct /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1_1.bct /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1_2.bct /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1_3.bct /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1_4.bct
[ 4.7340 ] Packing sdram param for instance[0]
[ 4.8008 ] Packing sdram param for instance[1]
[ 4.8011 ] Packing sdram param for instance[2]
[ 4.8012 ] Packing sdram param for instance[3]
[ 4.8012 ] Packing sdram param for instance[4]
[ 4.8012 ] Packing sdram param for instance[5]
[ 4.8012 ] Packing sdram param for instance[6]
[ 4.8013 ] Packing sdram param for instance[7]
[ 4.8013 ] Packing sdram param for instance[8]
[ 4.8013 ] Packing sdram param for instance[9]
[ 4.8013 ] Packing sdram param for instance[10]
[ 4.8013 ] Packing sdram param for instance[11]
[ 4.8013 ] Packing sdram param for instance[12]
[ 4.8013 ] Packing sdram param for instance[13]
[ 4.8013 ] Packing sdram param for instance[14]
[ 4.8013 ] Packing sdram param for instance[15]
[ 4.8013 ]
[ 4.8014 ] Getting sector size from pt
[ 4.8026 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 4.8037 ]
[ 4.8038 ] BlockSize read from layout is 200
[ 4.8049 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1_1.bct /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1_2.bct /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1_3.bct /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1_4.bct
[ 4.8058 ] adding BCH for /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1_1.bct
[ 4.8087 ]
[ 4.8096 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 4.8106 ]
[ 4.8117 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot.bct zerosbk
[ 4.8126 ] Header already present for mem_coldboot.bct
[ 4.8130 ]
[ 4.8142 ] tegrasign_v2 --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.8151 ] Assuming zero filled SBK key
[ 4.8156 ]
[ 4.8169 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[ 4.8182 ]
[ 4.8183 ] Generating recovery mem-bct
[ 4.8194 ] tegrabct_v2 --chip 0x19 0 --sdram /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1.cfg --membct /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1_1.bct /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1_2.bct /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1_3.bct /home/cowlar/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/22822/tmppplm0mim1_4.bct
[ 4.8203 ] Packing sdram param for instance[0]
[ 4.8871 ] Packing sdram param for instance[1]
[ 4.8874 ] Packing sdram param for instance[2]
[ 4.8876 ] Packing sdram param for instance[3]
[ 4.8876 ] Packing sdram param for instance[4]
[ 4.8876 ] Packing sdram param for instance[5]
[ 4.8876 ] Packing sdram param for instance[6]
[ 4.8877 ] Packing sdram param for instance[7]
[ 4.8877 ] Packing sdram param for instance[8]
[ 4.8877 ] Packing sdram param for instance[9]
[ 4.8877 ] Packing sdram param for instance[10]
[ 4.8877 ] Packing sdram param for instance[11]
[ 4.8877 ] Packing sdram param for instance[12]
[ 4.8877 ] Packing sdram param for instance[13]
[ 4.8877 ] Packing sdram param for instance[14]
[ 4.8877 ] Packing sdram param for instance[15]
[ 4.8877 ]
[ 4.8879 ] Reading ramcode from backup chip_info.bin file
[ 4.8894 ] RAMCODE Read from Device: 2
[ 4.8895 ] Disabled BPMP dtb trim, using default dtb
[ 4.8895 ]
[ 4.8909 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 4.8919 ]
[ 4.8930 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm.bct zerosbk
[ 4.8939 ] adding BCH for mem_rcm.bct
[ 4.8954 ]
[ 4.8967 ] tegrasign_v2 --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.8977 ] Assuming zero filled SBK key
[ 4.8979 ]
[ 4.8994 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[ 4.9017 ]
[ 4.9018 ] Copying signatures
[ 4.9028 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 7.2413 ]
[ 7.2414 ] Boot Rom communication
[ 7.2433 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 7.2443 ] BR_CID: 0x88021911647d15030400000002010040
[ 7.3128 ] RCM version 0X190001
[ 7.4209 ] Boot Rom communication completed
[ 8.4374 ]
[ 9.4405 ] tegrarcm_v2 --isapplet
[ 9.4420 ] Applet version 01.00.0000
[ 9.6242 ]
[ 9.6243 ] Sending BCTs
[ 9.6262 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[ 9.6276 ] Applet version 01.00.0000
[ 9.8406 ] Sending bct_bootrom
[ 9.8409 ] [................................................] 100%
[ 9.8434 ] Sending bct_mb1
[ 9.8489 ] [................................................] 100%
[ 9.8543 ] Sending bct_mem
[ 9.9006 ] [................................................] 100%
[ 9.9851 ]
[ 9.9852 ] Generating blob
[ 9.9872 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194.bin
[ 9.9889 ]
[ 9.9905 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_cpu_t194.bin zerosbk
[ 9.9918 ] adding BCH for blob_nvtboot_recovery_cpu_t194.bin
[ 10.0036 ]
[ 10.0059 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 10.0071 ] Assuming zero filled SBK key
[ 10.0077 ]
[ 10.0091 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[ 10.0143 ]
[ 10.0157 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194.bin
[ 10.0168 ]
[ 10.0179 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_t194.bin zerosbk
[ 10.0189 ] adding BCH for blob_nvtboot_recovery_t194.bin
[ 10.0242 ]
[ 10.0256 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 10.0266 ] Assuming zero filled SBK key
[ 10.0271 ]
[ 10.0284 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_sigheader.bin.encrypt blob_nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[ 10.0318 ]
[ 10.0331 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr.bin
[ 10.0344 ]
[ 10.0355 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --ratchet_blob ratchet_blob.bin --appendsigheader blob_preboot_c10_prod_cr.bin zerosbk
[ 10.0366 ] Header already present for blob_preboot_c10_prod_cr.bin
[ 10.0372 ]
[ 10.0385 ] tegrasign_v2 --key None --list blob_preboot_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 10.0395 ] Assuming zero filled SBK key
[ 10.0399 ]
[ 10.0413 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_sigheader.bin.encrypt blob_preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 10.0431 ]
[ 10.0445 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr.bin
[ 10.0457 ]
[ 10.0468 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --ratchet_blob ratchet_blob.bin --appendsigheader blob_mce_c10_prod_cr.bin zerosbk
[ 10.0492 ] Header already present for blob_mce_c10_prod_cr.bin
[ 10.0520 ]
[ 10.0536 ] tegrasign_v2 --key None --list blob_mce_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 10.0548 ] Assuming zero filled SBK key
[ 10.0554 ]
[ 10.0564 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_sigheader.bin.encrypt blob_mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 10.0603 ]
[ 10.0615 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr.bin
[ 10.0624 ]
[ 10.0634 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_mts_c10_prod_cr.bin zerosbk
[ 10.0643 ] adding BCH for blob_mts_c10_prod_cr.bin
[ 10.1550 ]
[ 10.1565 ] tegrasign_v2 --key None --list blob_mts_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 10.1575 ] Assuming zero filled SBK key
[ 10.1617 ]
[ 10.1634 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_sigheader.bin.encrypt blob_mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 10.2120 ]
[ 10.2133 ] tegrahost_v2 --chip 0x19 --align blob_bpmp_t194.bin
[ 10.2144 ]
[ 10.2154 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp_t194.bin zerosbk
[ 10.2163 ] adding BCH for blob_bpmp_t194.bin
[ 10.2405 ]
[ 10.2421 ] tegrasign_v2 --key None --list blob_bpmp_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 10.2432 ] Assuming zero filled SBK key
[ 10.2444 ]
[ 10.2457 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp_t194_sigheader.bin.encrypt blob_bpmp_t194_sigheader.bin.hash zerosbk
[ 10.2628 ]
[ 10.2644 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p2888-a04.dtb
[ 10.2657 ]
[ 10.2670 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-a02-bpmp-p2888-a04.dtb zerosbk
[ 10.2680 ] adding BCH for blob_tegra194-a02-bpmp-p2888-a04.dtb
[ 10.2888 ]
[ 10.2903 ] tegrasign_v2 --key None --list blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 10.2914 ] Assuming zero filled SBK key
[ 10.2925 ]
[ 10.2940 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.hash zerosbk
[ 10.3094 ]
[ 10.3108 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194.bin
[ 10.3119 ]
[ 10.3135 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t194.bin zerosbk
[ 10.3148 ] adding BCH for blob_spe_t194.bin
[ 10.3176 ]
[ 10.3187 ] tegrasign_v2 --key None --list blob_spe_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 10.3197 ] Assuming zero filled SBK key
[ 10.3202 ]
[ 10.3217 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_sigheader.bin.encrypt blob_spe_t194_sigheader.bin.hash zerosbk
[ 10.3250 ]
[ 10.3262 ] tegrahost_v2 --chip 0x19 --align blob_tos-trusty_t194.img
[ 10.3272 ]
[ 10.3283 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-trusty_t194.img zerosbk
[ 10.3293 ] adding BCH for blob_tos-trusty_t194.img
[ 10.3420 ]
[ 10.3435 ] tegrasign_v2 --key None --list blob_tos-trusty_t194_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 10.3446 ] Assuming zero filled SBK key
[ 10.3453 ]
[ 10.3469 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-trusty_t194_sigheader.img.encrypt blob_tos-trusty_t194_sigheader.img.hash zerosbk
[ 10.3536 ]
[ 10.3551 ] tegrahost_v2 --chip 0x19 --align blob_eks.img
[ 10.3564 ]
[ 10.3577 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks.img zerosbk
[ 10.3588 ] adding BCH for blob_eks.img
[ 10.3590 ]
[ 10.3605 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 10.3615 ] Assuming zero filled SBK key
[ 10.3618 ]
[ 10.3631 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 10.3646 ]
[ 10.3656 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p2888-0001-p2822-0000.dtb
[ 10.3665 ]
[ 10.3675 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 10.3684 ] adding BCH for blob_tegra194-p2888-0001-p2822-0000.dtb
[ 10.3795 ]
[ 10.3810 ] tegrasign_v2 --key None --list blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 10.3827 ] Assuming zero filled SBK key
[ 10.3839 ]
[ 10.3852 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 10.3922 ]
[ 10.3940 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 10.3950 ] number of images in blob are 11
[ 10.3954 ] blobsize is 6381592
[ 10.3956 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 260032
[ 10.3987 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 130928
[ 10.3993 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[ 10.3999 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 143200
[ 10.4004 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[ 10.4010 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 856352
[ 10.4020 ] Added binary blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt of size 746752
[ 10.4026 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 94960
[ 10.4030 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt of size 402368
[ 10.4035 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[ 10.4039 ] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 287248
[ 10.4065 ]
[ 10.4066 ] Sending bootloader and pre-requisite binaries
[ 10.4079 ] tegrarcm_v2 --download blob blob.bin
[ 10.4087 ] Applet version 01.00.0000
[ 10.6768 ] Sending blob
[ 10.6770 ] [................................................] 100%
[ 11.5892 ]
[ 11.5911 ] tegrarcm_v2 --boot recovery
[ 11.5926 ] Applet version 01.00.0000
[ 11.7769 ]
[ 12.7800 ] tegrarcm_v2 --isapplet
[ 13.3787 ]
[ 13.3807 ] tegrarcm_v2 --ismb2
[ 13.5642 ]
[ 13.5704 ] tegradevflash_v2 --iscpubl
[ 13.5724 ] Bootloader version 01.00.0000
[ 13.6766 ] Bootloader version 01.00.0000
[ 13.6803 ]
[ 13.6803 ] Retrieving storage infomation
[ 13.6825 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
[ 13.6841 ] Applet is not running on device. Continue with Bootloader
[ 13.9446 ]
[ 13.9467 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
[ 13.9485 ] Bootloader version 01.00.0000
[ 14.0206 ] Saved platform info in storage_info.bin
[ 14.0247 ]
[ 14.0248 ] Flashing the device
[ 14.0267 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[ 14.0290 ]
[ 14.0306 ] tegradevflash_v2 --pt flash.xml.bin --create
[ 14.0319 ] Bootloader version 01.00.0000
[ 14.1285 ] Erasing sdmmc_boot: 3 ......... [Done]
[ 15.1698 ] Writing partition secondary_gpt with gpt_secondary_0_3.bin
[ 15.1707 ] [................................................] 100%
[ 15.2054 ] Erasing sdmmc_user: 3 ......... [Done]
[ 15.9906 ] Writing partition master_boot_record with mbr_1_3.bin
[ 15.9914 ] [................................................] 100%
[ 15.9940 ] Writing partition primary_gpt with gpt_primary_1_3.bin
[ 16.0017 ] [................................................] 100%
[ 16.0048 ] Writing partition secondary_gpt with gpt_secondary_1_3.bin
[ 16.0260 ] [................................................] 100%
[ 16.0493 ] Writing partition mb1 with mb1_t194_prod_sigheader.bin.encrypt
[ 16.0502 ] [................................................] 100%
[ 16.0615 ] Writing partition mb1_b with mb1_t194_prod_sigheader.bin.encrypt
[ 16.0893 ] [................................................] 100%
[ 16.1006 ] Writing partition spe-fw with spe_t194_sigheader.bin.encrypt
[ 16.2017 ] [................................................] 100%
[ 16.2075 ] Writing partition spe-fw_b with spe_t194_sigheader.bin.encrypt
[ 16.2286 ] [................................................] 100%
[ 16.2341 ] Writing partition mb2 with nvtboot_t194_sigheader.bin.encrypt
[ 16.2557 ] [................................................] 100%
[ 16.2640 ] Writing partition mb2_b with nvtboot_t194_sigheader.bin.encrypt
[ 16.2878 ] [................................................] 100%
[ 16.2956 ] Writing partition mts-preboot with preboot_c10_prod_cr_sigheader.bin.encrypt
[ 16.3195 ] [................................................] 100%
[ 16.3225 ] Writing partition mts-preboot_b with preboot_c10_prod_cr_sigheader.bin.encrypt
[ 16.4161 ] [................................................] 100%
[ 16.4192 ] Writing partition SMD with slot_metadata.bin
[ 16.4389 ] [................................................] 100%
[ 16.4455 ] Writing partition SMD_b with slot_metadata.bin
[ 16.4591 ] [................................................] 100%
[ 16.4619 ] Writing partition VER_b with emmc_bootblob_ver.txt
[ 16.4758 ] [................................................] 100%
[ 16.4788 ] Writing partition VER with emmc_bootblob_ver.txt
[ 16.4926 ] [................................................] 100%
[ 16.4956 ] Writing partition master_boot_record with mbr_1_3.bin
[ 16.5093 ] [................................................] 100%
[ 16.5122 ] Writing partition APP with system.img
[ 16.5202 ] [................................................] 100%
[ 274.1413 ] Writing partition mts-mce with mce_c10_prod_cr_sigheader.bin.encrypt
[ 274.1810 ] [................................................] 100%
[ 274.1886 ] Writing partition mts-mce_b with mce_c10_prod_cr_sigheader.bin.encrypt
[ 274.2088 ] [................................................] 100%
[ 274.2156 ] Writing partition mts-proper with mts_c10_prod_cr_sigheader.bin.encrypt
[ 274.2356 ] [................................................] 100%
[ 274.3887 ] Writing partition mts-proper_b with mts_c10_prod_cr_sigheader.bin.encrypt
[ 274.4093 ] [................................................] 100%
[ 274.5724 ] Writing partition cpu-bootloader with cboot_t194_sigheader.bin.encrypt
[ 274.5938 ] [................................................] 100%
[ 274.6111 ] Writing partition cpu-bootloader_b with cboot_t194_sigheader.bin.encrypt
[ 274.6327 ] [................................................] 100%
[ 274.6497 ] Writing partition bootloader-dtb with tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
[ 274.6714 ] [................................................] 100%
[ 274.6836 ] Writing partition bootloader-dtb_b with tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
[ 274.7050 ] [................................................] 100%
[ 274.7161 ] Writing partition secure-os with tos-trusty_t194_sigheader.img.encrypt
[ 274.7368 ] [................................................] 100%
[ 274.7531 ] Writing partition secure-os_b with tos-trusty_t194_sigheader.img.encrypt
[ 274.7747 ] [................................................] 100%
[ 274.7899 ] Writing partition eks with eks_sigheader.img.encrypt
[ 274.8111 ] [................................................] 100%
[ 274.8142 ] Writing partition eks_b with eks_sigheader.img.encrypt
[ 274.8340 ] [................................................] 100%
[ 274.8370 ] Writing partition bpmp-fw with bpmp_t194_sigheader.bin.encrypt
[ 274.8570 ] [................................................] 100%
[ 274.8894 ] Writing partition bpmp-fw_b with bpmp_t194_sigheader.bin.encrypt
[ 274.9141 ] [................................................] 100%
[ 274.9439 ] Writing partition bpmp-fw-dtb with tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt
[ 274.9695 ] [................................................] 100%
[ 274.9979 ] Writing partition bpmp-fw-dtb_b with tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt
[ 275.0216 ] [................................................] 100%
[ 275.0481 ] Writing partition xusb-fw with xusb_sil_rel_fw
[ 275.0712 ] [................................................] 100%
[ 275.0786 ] Writing partition xusb-fw_b with xusb_sil_rel_fw
[ 275.0861 ] [................................................] 100%
[ 275.0930 ] Writing partition rce-fw with camera-rtcpu-rce_sigheader.img.encrypt
[ 275.1008 ] [................................................] 100%
[ 275.1129 ] Writing partition rce-fw_b with camera-rtcpu-rce_sigheader.img.encrypt
[ 275.1335 ] [................................................] 100%
[ 275.1445 ] Writing partition adsp-fw with adsp-fw_sigheader.bin.encrypt
[ 275.1648 ] [................................................] 100%
[ 275.1704 ] Writing partition adsp-fw_b with adsp-fw_sigheader.bin.encrypt
[ 275.1904 ] [................................................] 100%
[ 275.1954 ] Writing partition sc7 with warmboot_t194_prod_sigheader.bin.encrypt
[ 275.2156 ] [................................................] 100%
[ 275.2205 ] Writing partition sc7_b with warmboot_t194_prod_sigheader.bin.encrypt
[ 275.2405 ] [................................................] 100%
[ 275.2449 ] Writing partition BMP with bmp.blob
[ 275.2646 ] [................................................] 100%
[ 275.2728 ] Writing partition BMP_b with bmp.blob
[ 275.2924 ] [................................................] 100%
[ 275.3001 ] Writing partition recovery with recovery_sigheader.img.encrypt
[ 275.3202 ] [................................................] 100%
[ 277.5617 ] Writing partition recovery-dtb with tegra194-p2888-0001-p2822-0000.dtb_sigheader.rec.encrypt
[ 277.5777 ] [................................................] 100%
[ 277.5931 ] Writing partition kernel-bootctrl with kernel_bootctrl.bin
[ 277.6151 ] [................................................] 100%
[ 277.6177 ] Writing partition kernel-bootctrl_b with kernel_bootctrl.bin
[ 277.6318 ] [................................................] 100%
[ 277.6345 ] Writing partition kernel with boot_sigheader.img.encrypt
[ 277.6485 ] [................................................] 100%
[ 279.4942 ] Writing partition kernel_b with boot_sigheader.img.encrypt
[ 279.5064 ] [................................................] 100%
[ 281.3511 ] Writing partition kernel-dtb with kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
[ 281.3637 ] [................................................] 100%
[ 281.3792 ] Writing partition kernel-dtb_b with kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
[ 281.4014 ] [................................................] 100%
[ 281.4325 ]
[ 281.4355 ] tegradevflash_v2 --write BCT br_bct_BR.bct
[ 281.4372 ] Bootloader version 01.00.0000
[ 281.5125 ] Writing partition BCT with br_bct_BR.bct
[ 281.5131 ] [................................................] 100%
[ 281.5726 ]
[ 281.5773 ] tegradevflash_v2 --write MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 281.5789 ] Bootloader version 01.00.0000
[ 281.6526 ] Writing partition MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 281.6537 ] [................................................] 100%
[ 281.6757 ]
[ 281.6779 ] tegradevflash_v2 --write MB1_BCT_b mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 281.6794 ] Bootloader version 01.00.0000
[ 281.7526 ] Writing partition MB1_BCT_b with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 281.7538 ] [................................................] 100%
[ 281.7756 ]
[ 281.7797 ] tegradevflash_v2 --write MEM_BCT mem_coldboot_sigheader.bct.encrypt
[ 281.7815 ] Bootloader version 01.00.0000
[ 281.9087 ] Writing partition MEM_BCT with mem_coldboot_sigheader.bct.encrypt
[ 281.9097 ] [................................................] 100%
[ 281.9307 ]
[ 281.9326 ] tegradevflash_v2 --write MEM_BCT_b mem_coldboot_sigheader.bct.encrypt
[ 281.9341 ] Bootloader version 01.00.0000
[ 282.0649 ] Writing partition MEM_BCT_b with mem_coldboot_sigheader.bct.encrypt
[ 282.0659 ] [................................................] 100%
[ 282.0863 ]
[ 282.0864 ] Flashing completed
[ 282.0865 ] Coldbooting the device
[ 282.0887 ] tegrarcm_v2 --ismb2
[ 282.3564 ]
[ 282.3584 ] tegradevflash_v2 --reboot coldboot
[ 282.3600 ] Bootloader version 01.00.0000
[ 282.5066 ]
*** The target t186ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
flash_logs.txt (64.0 KB)
