Based on the provided context, I’ll address your questions and concerns about the boot loading process of NVIDIA Orin NX r365.
1. Where is the Boot Configuration Table (BCT) stored?
The BCT is stored in the storage device, not in the rootfs. The BootROM loads the BCT from the storage device, which contains the configuration settings for the boot process.
2. Data corruption concerns
Your concern about data corruption is valid, especially if you’re dealing with a use case that’s prone to data corruption. Implementing a checksum before the M1 step is a good idea to validate the areas of memory that will be susceptible to corruption.
3. Secure Boot and Secure UEFI
Secure Boot and Secure UEFI are designed to provide a secure boot process, but they don’t necessarily handle data corruption. Secure Boot ensures that only authorized firmware is loaded during the boot process, while Secure UEFI provides a secure environment for the UEFI firmware to execute.
However, Secure Boot and Secure UEFI do provide some level of protection against data corruption. For example, Secure Boot can verify the integrity of the firmware and ensure that it’s not tampered with. Secure UEFI can also provide a secure environment for the firmware to execute, which can help prevent data corruption.
4. Resilient boot process
To achieve a resilient boot process, you may want to consider implementing additional measures, such as:
- Implementing a checksum or digital signature verification for the BCT and other critical firmware components.
- Using a secure storage device, such as a Trusted Platform Module (TPM), to store sensitive data.
- Implementing a robust error detection and correction mechanism to detect and correct data corruption.
- Using a secure boot loader, such as UEFI Secure Boot, to ensure that only authorized firmware is loaded during the boot process.
Comparison with other Jetson modules
The boot loading process of NVIDIA Orin NX r365 is similar to other Jetson modules, such as Jetson AGX Orin, Jetson Xavier NX, and Jetson AGX Xavier. However, there may be some differences in the specific implementation details.
For example, Jetson AGX Orin and Jetson Orin NX use a similar boot flow, which includes BootROM, PSCROM, MB1, MB2, and UEFI. However, Jetson Xavier NX and Jetson AGX Xavier use a different boot flow, which includes BootROM, Bootloader Components, TegraBoot, and UEFI.
In summary, to achieve a resilient boot process on NVIDIA Orin NX r365, you should implement additional measures, such as checksum verification, secure storage, and robust error detection and correction. Secure Boot and Secure UEFI can provide some level of protection against data corruption, but they don’t necessarily handle data corruption.
