SecureBoot and Encrypted RootFs
My Goal:
To have SecureBoot and Encrypted RootFs setup.
My Setup:
35.4.1
NVME 500Gb
Ubuntu 18.04 host
Orin Nano DevKit
Notes:
I don’t mind that my keys here are public, I will generate new ones for production.
SETUP DIRECTORY
sudo systemctl stop udisks2
sudo -s echo -1 > /sys/module/usbcore/parameters/autosuspend
apt-get install dislocker cryptsetup libcryptsetup-dev libcryptsetup12 cryptmount cryptmount overlayroot
pip install cryptography
pip install pycrypto
mkdir tmp
cd tmp
wget https://developer.nvidia.com/downloads/embedded/l4t/r35_release_v4.1/release/jetson_linux_r35.4.1_aarch64.tbz2
tar xvf jetson_linux_r35.4.1_aarch64.tbz2
wget https://developer.nvidia.com/downloads/embedded/l4t/r35_release_v4.1/release/tegra_linux_sample-root-filesystem_r35.4.1_aarch64.tbz2
sudo tar xvf tegra_linux_sample-root-filesystem_r35.4.1_aarch64.tbz2 -C Linux_for_Tegra/rootfs/
wget https://developer.nvidia.com/embedded/l4t/r35_release_v1.0/sources/public_sources.tbz2
tar xvf public_sources.tbz2
cd Linux_for_Tegra/source/public/
tar xvf nvidia-jetson-optee-source.tbz2
cd ../..
sudo ./apply_binaries.sh
CREATE KEYS
openssl genrsa -out rsa.pem 3072
PKCS_KEY_XML_HASH=$(./bootloader/tegrasign_v3.py --pubkeyhash rsa.pubkey rsa.hash --key rsa.pem | grep "tegra-fuse format" | awk '{print $NF}')
echo "PKCS Key Hash: ${PKCS_KEY_XML_HASH}"
SBK_0=$(openssl rand -hex 4)
SBK_1=$(openssl rand -hex 4)
SBK_2=$(openssl rand -hex 4)
SBK_3=$(openssl rand -hex 4)
SBK_4=$(openssl rand -hex 4)
SBK_5=$(openssl rand -hex 4)
SBK_6=$(openssl rand -hex 4)
SBK_7=$(openssl rand -hex 4)
SBK_KEY=$(echo "0x${SBK_0} 0x${SBK_1} 0x${SBK_2} 0x${SBK_3} 0x${SBK_4} 0x${SBK_5} 0x${SBK_6} 0x${SBK_7}")
echo "${SBK_KEY}" > sbk.key
SBK_KEY_XML="0x${SBK_0}${SBK_1}${SBK_2}${SBK_3}${SBK_4}${SBK_5}${SBK_6}${SBK_7}"
echo "${SBK_KEY_XML}" > sbk_xml.key
echo "SBK Key: ${SBK_KEY_XML}"
KEK_2_0=$(openssl rand -hex 4)
KEK_2_1=$(openssl rand -hex 4)
KEK_2_2=$(openssl rand -hex 4)
KEK_2_3=$(openssl rand -hex 4)
KEK_2_4=$(openssl rand -hex 4)
KEK_2_5=$(openssl rand -hex 4)
KEK_2_6=$(openssl rand -hex 4)
KEK_2_7=$(openssl rand -hex 4)
KEK_2_KEY=$(echo "0x${KEK_2_0} 0x${KEK_2_1} 0x${KEK_2_2} 0x${KEK_2_3} 0x${KEK_2_4} 0x${KEK_2_5} 0x${KEK_2_6} 0x${KEK_2_7}")
echo "${KEK_2_KEY}" > kek.key
KEK_2_KEY_XML="0x${KEK_2_0}${KEK_2_1}${KEK_2_2}${KEK_2_3}${KEK_2_4}${KEK_2_5}${KEK_2_6}${KEK_2_7}"
echo "${KEK_2_KEY_XML}" > kek_xml.key
KEK_2_KEY_OPTEE="${KEK_2_0}${KEK_2_1}${KEK_2_2}${KEK_2_3}${KEK_2_4}${KEK_2_5}${KEK_2_6}${KEK_2_7}"
echo "${KEK_2_KEY_OPTEE}" > kek_optee.key
echo "KEK1 Key: ${KEK_2_KEY_XML}"
FUSE KEYS
echo "<genericfuse MagicId=\"0x45535546\" version=\"1.0.0\">" > fuse.xml
echo "  <fuse name=\"PublicKeyHash\" size=\"64\" value=\"${PKCS_KEY_XML_HASH}\"/>" >> fuse.xml
echo "  <fuse name=\"SecureBootKey\" size=\"32\" value=\"${SBK_KEY_XML}\"/>" >> fuse.xml
echo "  <fuse name=\"OemK2\" size=\"32\" value=\"${KEK_2_KEY_XML}\"/>" >> fuse.xml
echo "  <fuse name=\"BootSecurityInfo\" size=\"4\" value=\"0x209\"/>" >> fuse.xml
echo "</genericfuse>" >> fuse.xml
sudo ./odmfuse.sh -i 0x23 -k rsa.pem -S sbk.key -X fuse.xml jetson-orin-nano-devkit
fuselog.txt (164.7 KB)
fuse.xml
<genericfuse MagicId="0x45535546" version="1.0.0">
  <fuse name="PublicKeyHash" size="64" value="0x109e54402e467bcff463fe2c9e58990248259989dca0db3e7ee6ce7b44d77e46e0ee07af56eec2ebd696fab0877ab9641f94776cbf5042478c7233be5f3f0270"/>
  <fuse name="SecureBootKey" size="32" value="0x3e75e2bb00844cd55a004e99031f4279ba4f5c940ab598bb8867c940acf28045"/>
  <fuse name="OemK2" size="32" value="0xf4947b9acb100648779921b6ebb4c9f982a77540cfd525e48ee30e48d5fcc38e"/>
  <fuse name="BootSecurityInfo" size="4" value="0x209"/>
</genericfuse>
GENERATE OPTEE IMAGE
echo "bad66eb4484983684b992fe54a648bb8" > fv_ekb_t234
echo "010203040506070809a0b0c0d0e0f001" > sym_t234.key
echo "f0e0d0c0b0a001020304050607080900" > sym2_t234.key
rm bootloader/eks_t234.img
python3 ./source/public/optee/samples/hwkey-agent/host/tool/gen_ekb/gen_ekb.py -chip t234 -oem_k2_key kek_optee.key -fv fv_ekb_t234 -in_sym_key sym_t234.key -in_sym_key2 sym2_t234.key -out bootloader/eks_t234.img
CREATE FLASH IMAGES
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --network usb0 -u ./rsa.pem -v ./sbk.key --no-flash --showlogs -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" jetson-orin-nano-devkit internal
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs -u ./rsa.pem -v ./sbk.key --no-flash --external-device nvme0n1p1 -i ./sym2_t234.key -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml -S 60GiB --external-only --append --network usb0 jetson-orin-nano-devkit external
qspi.txt (338.2 KB)
nvme.txt (237.8 KB)
FLASH
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs -u rsa.pem -v sbk.key --network usb0 --flash-only
flashlog.txt (41.5 KB)
deviceflashlog.txt (88.0 KB)
BOOT LOG
bootlog.txt (53.1 KB)
In the bootlog I end up with “ERROR: fail to unlock the encrypted dev /dev/nvme0n1p2”. As far as I can tell, I am following the secure boot documentation and have tried various varieties of options and still end up with the same result. Some parts I am unsure about are whether I need to change the OpTee image, and if I am passing in the correct keys to generate the OpTee image. What parts of the fuses do I need to set, and whether I am filling them with the correct values.
hello chrisward9000,
this failure shows incorrect eks image were used.
please examine your EKS image, you may see-also Topic 271974 for checking those 4 magic bytes in the beginning of the EKS image.
You are correct.
hexdump -C -n 4 -s 0x24 bootloader/eks_t234.img
00000024  12 06 ca 92                                       |....|
00000028
I had downloaded public_sources.tbz2 from here(WRONG):
Instead of here(CORRECT):
wget https://developer.nvidia.com/downloads/embedded/l4t/r35_release_v4.1/sources/public_sources.tbz2/
Using the correct public_sources.tbz2.
00000024  45 45 4b 42                                       |EEKB|
00000028
I now have a bootable system that appears to be using SecureBoot with an encrypted RootFs.
