Security -- Jetson Orin Nano
Incidentally, if you have the fuses burned with a key, then the kernel can only be loaded from a correctly signed kernel partition. Flash itself puts the kernel into the partition if you adjust the flash to use your key and if that key matches the burned fuses.
