On Nobara 41, KDE 6.3, kernel is Linux 6.13.2-200.nobara.fc41.x86_64
Prior to today, I would get the flip event timeout issue where the display would freeze, you could still hear sound and it required a switch over to TTY 3 and then back and it would fix. But today, when it happens, the monitor goes black, I can’t switch to TTY 3, I can still hear sound for a little bit until the whole thing crashes and requires me to do a hard reset.
Here is the pastebin for the boot log where the big things are this:
Feb 14 14:46:47 nobara-pc kwin_wayland[3425]: kwin_wayland_drm: Checking test buffer failed!
Feb 14 14:46:47 nobara-pc kwin_wayland[3425]: kwin_core: Applying output config failed!
Feb 14 14:46:47 nobara-pc kernel: NVRM: nvAssertFailedNoLog: Assertion failed: NV_OK == rmStatus @ video_mem.c:656
Feb 14 14:46:47 nobara-pc kernel: [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
Feb 14 14:46:47 nobara-pc kwin_wayland[3425]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Feb 14 14:46:47 nobara-pc kwin_wayland[3425]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Feb 14 14:46:48 nobara-pc kwin_wayland[3425]: kwin_wayland_drm: No drm events for gpu "/dev/dri/card0" within last 1 second
Feb 14 14:46:52 nobara-pc kernel: nvidia-modeset: ERROR: GPU:0: Failed detecting connected display devices
Feb 14 14:46:52 nobara-pc kernel: nvidia-modeset: WARNING: GPU:0: Failure processing EDID for display device DP-0.
Feb 14 14:46:52 nobara-pc kernel: nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device DP-0
Feb 14 14:46:52 nobara-pc kernel: NVRM: nvAssertFailedNoLog: Assertion failed: NV_OK == rmStatus @ video_mem.c:656
Feb 14 14:46:52 nobara-pc kernel: [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
nvidia-bug-report.log.gz (465.8 KB)
