Hello, I have a problem with my Nvidia Xavier NX Developer Kit board.
I have been able to flash it twice before and it was working. I uninstalled OS from SDKManager and now when I plug it, the led goes on, it is detected by sdkmanager but it doesn’t boot. if I run lsusb I can see it too.
edit: I tried to flash 2 different SD Cards and the result is the same, either with the dd command or with Etcher
From the SDK I selected Uninstall / Repair option then did “Uninstall” in front of “Target components (Jetson Xavier NX [Developper Kit Version])” with the board connected
I don’t think uninstall really did anything to your board… it seems only remove the folder on your host but not your jetson device.
Have you flashed your cards with sdkmanager?
