I have a problem with my hybrid application(OpenMPI+OpenMP) written in FORTRAN90(PGI-Fortran 8.0-6, latest one).
The error is as follows:
[server:02656] *** Process received signal ***
[server:02656] Signal: Segmentation fault (11)
[server:02656] Signal code: Address not mapped (1)
[server:02656] Failing at address: 0x283a3b70
[server:02656] *** End of error message ***
Segmentation fault
$ldd Solver (my application):
libmpi_f90.so.0 => /opt/mpi/openmpi-pgi/lib/libmpi_f90.so.0 (0x00002ba7d7267000)
libmpi_f77.so.0 => /opt/mpi/openmpi-pgi/lib/libmpi_f77.so.0 (0x00002ba7d746a000)
libmpi.so.0 => /opt/mpi/openmpi-pgi/lib/libmpi.so.0 (0x00002ba7d7980000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x0000003eeb800000)
libopen-rte.so.0 => /opt/mpi/openmpi-pgi/lib/libopen-rte.so.0 (0x00002ba7d8072000)
libopen-pal.so.0 => /opt/mpi/openmpi-pgi/lib/libopen-pal.so.0 (0x00002ba7d8354000)
libdl.so.2 => /lib64/libdl.so.2 (0x0000003eeb400000)
libnsl.so.1 => /lib64/libnsl.so.1 (0x0000003ef3800000)
libutil.so.1 => /lib64/libutil.so.1 (0x0000003ef8a00000)
libpgmp.so => /opt/pgi/linux86-64/8.0-6/libso/libpgmp.so (0x00002ba7d8631000)
libpgbind.so => /opt/pgi/linux86-64/8.0-6/libso/libpgbind.so (0x00002ba7d875b000)
libnuma.so.1 => /usr/lib64/libnuma.so.1 (0x0000003eea000000)
libpgf90.so => /opt/pgi/linux86-64/8.0-6/libso/libpgf90.so (0x00002ba7d885d000)
libpgf90_rpm1.so => /opt/pgi/linux86-64/8.0-6/libso/libpgf90_rpm1.so (0x00002ba7d8c19000)
libpgf902.so => /opt/pgi/linux86-64/8.0-6/libso/libpgf902.so (0x00002ba7d8d1b000)
libpgf90rtl.so => /opt/pgi/linux86-64/8.0-6/libso/libpgf90rtl.so (0x00002ba7d8e2e000)
libpgftnrtl.so => /opt/pgi/linux86-64/8.0-6/libso/libpgftnrtl.so (0x00002ba7d8f51000)
libpgc.so => /opt/pgi/linux86-64/8.0-6/libso/libpgc.so (0x00002ba7d907f000)
librt.so.1 => /lib64/librt.so.1 (0x0000003eef400000)
libm.so.6 => /lib64/libm.so.6 (0x0000003eeb000000)
libc.so.6 => /lib64/libc.so.6 (0x0000003eeac00000)
/lib64/ld-linux-x86-64.so.2 (0x0000003ee9c00000)
Compile/linker flags are:
FFLAGS = -mcmodel=medium -fastsse -O3 -Mcache_align -mp
LOADOPTS= $(FFLAGS)
However, if I remove “-mp”, it works well without faults.
Furthermore, If I use PGI Fortran 6.2, it works well with “-mp”.
If I change the order of libc and libopen-pal using some linker-option, it also works with “-mp”, namely
libopen-rte.so.0 => /opt/mpi/openmpi-1.3.2-pgi6.2/lib/libopen-rte.so.0 (0x00002ad3e2764000)
libopen-pal.so.0 => /opt/mpi/openmpi-1.3.2-pgi6.2/lib/libopen-pal.so.0 (0x00002ad3e2a47000)
is OK.
I saw the same trouble before in this forum. But it seems to be unsolved yet. I think that the trouble may be caused by PGI-Fortran8.0, esspecially the conflict between OpenMP and OpenMPI. Does anyone help me?
tmishima
