I have kernel which is defined as
Function(__constant uchar *buf, __constant ushort buflen, __constant uint m, __constant uchar *table, __constant uint *search_B2G, __global uint *mts, __global uint *o)
If I call this kernel I get a Segfault from within the libOpenCL. If I modify the kernel definition to
Function(__constant uchar *buf, __constant ushort buflen, __constant uint m, __global uchar *table, __global uint *search, __global uint *mts, __global uint *o)
where I have changed table and search to __global instead of __constant and it works fine now without any seg fault. I checked the max no of __constant kernel args that can be supplied to a kernel on my device is 9, so exceeding the limit is ruled out. Also none of my buffers cross 64K, which is the minimum for a constant buffer. Both table and search are buffers defined using CL_MEM_READ_ONLY. I am not sure why I am getting the seg fault while changing the modifier to any of these 2 args to __constant from __global.
P.S. Sorry for the topic. Never noticed the errors. A more apt title would be “Seg fault inside kernel with varying constant args”
