I have a particular model that causes a seg fault when converting to INT8 for DLA on Jetson Xavier. The model works fine when converting to INT8 using GPU. My other models convert fine to GPU and DLA.
I am using the C++ API. I can share the model if needed.
I guess my question is that with 1 particular model I have, it seg faults when I convert it to INT8 targeting DLA. The model does not segfault when I target GPU.
I am able to convert my other models to both INT8 and GPU without problem.
