Hi everyone,
I seem to be running into a seg-fault with the CUDA 3.1 beta, that I cannot reproduce with CUDA 3.0. The code below tries to just initialize CUDA and CUBLAS (Thanks to Dan Price from EMP for sharing this).
#include "cuda.h"
#include "cublas.h"
#include <stdio.h>
#define MSG() printf("%s:%d\n", __FILE__, __LINE__);
int main(int argc, char** argv)
struct{
void operator()(CUresult r) { if(r) exit(r); }
void operator()(cublasStatus r) { if(r) exit(r); }
}CheckError;
CUcontext cuContext;
MSG();
CheckError( cuInit(0) );
MSG();
CheckError( cuCtxCreate(&cuContext, 0, 0) );
MSG();
CheckError( cublasInit() );
MSG();
CheckError( cuCtxDetach(cuContext) );
MSG();
return 0;
Running it in gdb gives the following output and stack-trace.
(gdb) r
Starting program: /home/sandeep/res
[Thread debugging using libthread_db enabled]
test.cu:15
test.cu:17
test.cu:19
[New Thread 0x7ffff4339700 (LWP 5803)]
test.cu:21
test.cu:23
Program received signal SIGSEGV, Segmentation fault.
std::_Rb_tree_rebalance_for_erase (__z=<value optimized out>, __header=@0x6985a0) at ../../../../libstdc++-v3/src/tree.cc:386
386 if ((__w->_M_right == 0 ||
(gdb) bt
#0 std::_Rb_tree_rebalance_for_erase (__z=<value optimized out>, __header=@0x6985a0) at ../../../../libstdc++-v3/src/tree.cc:386
#1 0x00007ffff4354659 in ?? () from /usr/local/cuda/lib64/libcudart.so.3
#2 0x0000003db3210238 in ?? () from /lib64/libc.so.6
#3 0x00007ffff433e790 in ?? () from /usr/local/cuda/lib64/libcudart.so.3
#4 0x0000000100000000 in ?? ()
#5 0x000000010000083a in ?? ()
#6 0x0000000000000028 in ?? ()
#7 0x00007ffff4f4c838 in ?? ()
#8 0x00007fffffffdc30 in ?? ()
#9 0x000000000062bdd0 in ?? ()
#10 0x000000000062bdb0 in ?? ()
#11 0x00007ffff456f968 in pthread_mutex_unlock () at forward.c:184
#12 0x0000000000696af0 in ?? ()
#13 0x000000000062bdd0 in ?? ()
#14 0x0000000000000004 in ?? ()
#15 0x00007ffff434a22c in ?? () from /usr/local/cuda/lib64/libcudart.so.3
#16 0x00007ffff456f998 in pthread_mutex_unlock () at forward.c:184
#17 0x000000000062bdb0 in ?? ()
#18 0x00007ffff456f960 in pthread_mutex_unlock () at forward.c:184
#19 0x00007ffff456f998 in pthread_mutex_unlock () at forward.c:184
#20 0x00007ffff456f998 in pthread_mutex_unlock () at forward.c:184
#21 0x00007ffff434db5b in ?? () from /usr/local/cuda/lib64/libcudart.so.3
#22 0x00007ffff434e27a in ?? () from /usr/local/cuda/lib64/libcudart.so.3
#23 0x00007ffff4343198 in __cudaUnregisterFatBinary () from /usr/local/cuda/lib64/libcudart.so.3
#24 0x0000003db3236960 in __cxa_finalize (d=0x7ffff7fe42a0) at cxa_finalize.c:56
#25 0x00007ffff4f8ae66 in sqrtf () at w_sqrtf.c:33
#26 0x0000000000000000 in ?? ()
The seg-fault doesn’t appear if I don’t call cublasInit() . I’ve tested this with Fedora 10 (64-bit) Linux. Thanks in advance for the suggestions to resolve this.
Thanks,
Sandeep.
