Hi!
I encounter a segmentation fault when using exceptions and linking against libcudart_static.a
. The problem goes away when linking against libcudart.so
. I’m curious to learn why this happens. Below is a description of my setup.
Source code:
#include <stdexcept>
#include <cuda_runtime.h>
void foo()
throw std::runtime_error("Foo");
int main()
int* ptr{};
auto err = cudaMalloc(&ptr, 128);
if (cudaSuccess != err)
return 1;
try {
foo();
catch (const std::runtime_error&)
Backtrace:
#0 linear_search_fdes (ob=0x7fffffffd580, this_fde=0x0, pc=0x403df7 <foo()+65>) at ../../../gcc/libgcc/unwind-dw2-fde.c:969
#1 0x00007ffff7dc0e11 in find_fde_tail (dbase=18446744073709383432, bases=0x7fffffffd7d8, hdr=0x4aa594, pc=4210167) at ../../../gcc/libgcc/unwind-dw2-fde-dip.c:519
#2 _Unwind_Find_FDE (pc=<optimized out>, bases=bases@entry=0x7fffffffd7d8) at ../../../gcc/libgcc/unwind-dw2-fde-dip.c:573
#3 0x00007ffff7dbc4aa in uw_frame_state_for (context=0x7fffffffd730, fs=0x7fffffffd820) at ../../../gcc/libgcc/unwind-dw2.c:1005
#4 0x00007ffff7dbdefd in _Unwind_RaiseException (exc=0xcfc520) at ../../../gcc/libgcc/unwind.inc:104
#5 0x00007ffff79fdd8a in __cxa_throw ()
from /path/to/libstdc++.so.6
#6 0x0000000000403df8 in foo() ()
#7 0x0000000000403e44 in main ()
I am running this on the following setup:
- Ubuntu 20.04.
- cuda-cudart-11-7_11.7.99-1_amd64.deb.
- GCC 13.1 built from source.
I am aware that NVCC does not support GCC > 11, but in this case I’m not using NVCC, just plain C++ code and linking external libraries, so I don’t see the reason why it shouldn’t work. We’d prefer to keep linking cudart statically instead of dynamically.
Do you have any feeling for what the problem might be?
