• Hardware Platform (Jetson / GPU): Jetson Nano
• DeepStream Version: 5.0.1
• JetPack Version (valid for Jetson only): 4.4
• TensorRT Version: N/A
• NVIDIA GPU Driver Version (valid for GPU only): N/A
• Issue Type( questions, new requirements, bugs): bug
• How to reproduce the issue ?: Described below
• Requirement details: N/A
Segmentation fault is caused when nvv4l2h265enc
and nvvideoconvert
are used together.
More specifically, in my observation, it is caused when the following conditions are met:
nvvideoconvert
element is instantiated. (not necessarily added to a gstreamer pipeline) -
nvv4l2h265enc
(ornvv4l2h264enc
) is running in a pipeline.
Details:
Code
import sys
import time
import gi
gi.require_version('Gst', '1.0')
from gi.repository import GObject, Gst
def make_gst_element(factoryname, name=None, *, props=None):
if name is None:
name = factoryname
element = Gst.ElementFactory.make(factoryname, name)
if not element:
raise RuntimeError(f"Unable to create streamer element: {factoryname}")
if props:
for key, value in props.items():
element.set_property(key, value)
return element
def main():
GObject.threads_init()
Gst.init(None)
# Set True to cause segfault.
bad = True
# Create pipeline
pipeline = Gst.Pipeline()
if not pipeline:
raise RuntimeError("Unable to create Pipeline")
source = make_gst_element(
"nvarguscamerasrc",
props={
'sensor-id': 0,
image_width = 816
image_height = 616
capsfilter = make_gst_element(
"capsfilter",
props={
"caps": Gst.Caps.from_string(f"video/x-raw(memory:NVMM), width=(int){image_width}, height=(int){image_height}, format=(string)NV12, framerate=(fraction)21/1"),
if bad:
encoder = make_gst_element("nvv4l2h265enc")
fakesink = make_gst_element("fakesink")
# Only instantiated (not even added to the pipeline)
make_gst_element("nvvideoconvert")
# Add to pipeline
pipeline.add(source)
pipeline.add(capsfilter)
pipeline.add(fakesink)
if bad:
pipeline.add(encoder)
# Link
source.link(capsfilter)
if bad:
capsfilter.link(encoder)
encoder.link(fakesink)
else:
capsfilter.link(fakesink)
# Start
if pipeline.set_state(Gst.State.PLAYING) == Gst.StateChangeReturn.FAILURE:
raise RuntimeError('Unable to start gstreamer pipeline')
try:
while True:
time.sleep(10)
finally:
pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
try:
main()
except KeyboardInterrupt:
sys.exit(1)
except:
import traceback
traceback.print_exc()
import pdb
pdb.post_mortem()
Output
$ GST_DEBUG=3 python3 bad.py
Opening in BLOCKING MODE
0:00:00.116061984 3673 0x317dbb60 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x31777a40 Failed to determine interlace mode
0:00:00.116144485 3673 0x317dbb60 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x31777a40 Failed to determine interlace mode
0:00:00.116214069 3673 0x317dbb60 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x31777a40 Failed to determine interlace mode
0:00:00.116334019 3673 0x317dbb60 WARN v4l2 gstv4l2object.c:4430:gst_v4l2_object_probe_caps:<nvv4l2h265enc:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown err
or -1
0:00:00.116905329 3673 0x314dc8a0 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:<nvarguscamerasrc:src> Creating random stream-id, consider implementing a determinist
ic way of creating a stream-id
NvMMLiteOpen : Block : BlockType = 8
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
0:00:00.139390069 3673 0x314dc8a0 WARN v4l2bufferpool gstv4l2bufferpool.c:1057:gst_v4l2_buffer_pool_start:<nvv4l2h265enc:pool:src> Uncertain or not enough buffers, enabling copy threshold
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 4
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120.000005
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
Output (gdb)
(gdb) cont
Continuing.
[New Thread 0x7fb40631f0 (LWP 7260)]
[New Thread 0x7fb38621f0 (LWP 7261)]
[New Thread 0x7fb30611f0 (LWP 7262)]
[New Thread 0x7fb28601f0 (LWP 7263)]
[New Thread 0x7fafd741f0 (LWP 7264)]
0:00:00.652504935 6775 0xde3760 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0xd7ed00 Failed to determine interlace mode
0:00:00.652594988 6775 0xde3760 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0xd7ed00 Failed to determine interlace mode
0:00:00.652647020 6775 0xde3760 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0xd7ed00 Failed to determine interlace mode
0:00:00.652744782 6775 0xde3760 WARN v4l2 gstv4l2object.c:4430:gst_v4l2_object_probe_caps:<nvv4l2h265enc:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
[New Thread 0x7faf3ac1f0 (LWP 7265)]
0:00:00.653799692 6775 0xae34a0 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:<nvarguscamerasrc:src> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
[New Thread 0x7faebab1f0 (LWP 7266)]
[New Thread 0x7fae3aa1f0 (LWP 7267)]
[New Thread 0x7fadba91f0 (LWP 7269)]
0:00:00.677425387 6775 0xae34a0 WARN v4l2bufferpool gstv4l2bufferpool.c:1057:gst_v4l2_buffer_pool_start:<nvv4l2h265enc:pool:src> Uncertain or not enough buffers, enabling copy threshold
[New Thread 0x7f8ffff1f0 (LWP 7409)]
[New Thread 0x7f8f7fe1f0 (LWP 7410)]
[New Thread 0x7f8effd1f0 (LWP 7411)]
Camera index = 0
Camera mode = 4
seconds to Run = 0
[New Thread 0x7f8e7fc1f0 (LWP 7414)]
Thread 7 "nvarguscamerasr" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7faf3ac1f0 (LWP 7265)]
0x0000007fb0a5f170 in ?? () from /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so
(gdb) bt
#0 0x0000007fb0a5f170 in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so
#1 0x0000007fb0a63458 in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so
#2 0x0000007fb0a7700c in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so
#3 0x0000007fb68ae774 in () at /usr/lib/aarch64-linux-gnu/libgstvideo-1.0.so.0
#4 0x0000000000b18e00 in ()
