I’m trying to profile my application with the visual profiler, however the profiler returns:
Error: Application received signal 139
Which corresponds to a segmentation fault. When I run cuda-memcheck I get internal error 20, segmentation fault in the host code. The application runs fine both normally and in cuda-gdb. However when I enable cuda-memcheck in cuda-gdb I get a segmentation fault in cuInit(0). Here is the backtrace:
#0 0x000eeaec in cuGetExportTable ()
#1 0xf6824534 in cudbgGetAPIVersion ()
from /usr/lib/arm-linux-gnueabihf/libcuda.so
#2 0xf6721b08 in cuMemGetAttribute_v2 ()
#3 0xf66476d8 in cuInit () from /usr/lib/arm-linux-gnueabihf/libcuda.so
This problem occurs on multiple devices.
