I installed the latest developer drivers (195.36.15) for my 8600M GT NVIDIA card, the toolkit for ubuntu (I am using Kubuntu 10.04) and the latest GPU Computing SDK. I managed to compile all the examples using gcc 4.4.3. The problem is that when I try to run an example, I get a segmentation fault. Here’s what I get in gdb when I try to run deviceQuery:
codebox run
Starting program: /home/frounk/NVIDIA_GPU_Computing_SDK/C/bin/linux/debug/deviceQuery
[Thread debugging using libthread_db enabled]
Program received signal SIGSEGV, Segmentation fault.
0x000000000041c4a0 in strlen ()
(gdb) bt
#0 0x000000000041c4a0 in strlen ()
#1 0x0000000000403a49 in shrSetLogFileName (cOverRideName=0x4128a2 “deviceQuery.txt”) at src/shrUtils.cpp:193
#2 0x0000000000402f28 in main (argc=1, argv=0x7fffffffe228) at deviceQuery.cpp:29
(gdb) up
193 cLogFilePathAndName = (char*) malloc(strlen(cOverRideName) + 1);
(gdb) list
188 void shrSetLogFileName (const char* cOverRideName)
189 {
190 if( cLogFilePathAndName != NULL ) {
191 free(cLogFilePathAndName);
192 }
194 #ifdef WIN32
195 strcpy_s(cLogFilePathAndName, strlen(cOverRideName) + 1, cOverRideName);
196 #else
197 strcpy(cLogFilePathAndName, cOverRideName);
(gdb) up
29 shrSetLogFileName (“deviceQuery.txt”);
(gdb) list
24 // Program main
25 ////////////////////////////////////////////////////////////////////////////////
26 int
27 main( int argc, const char** argv)
28 {
30 shrLog("%s Starting…\n\n", argv[0]);
31 shrLog(" CUDA Device Query (Runtime API) version (CUDART static linking)\n\n");
32
33 int deviceCount = 0;
(gdb) down
(gdb) p cOverRideName
$1 = 0x4128a2 “deviceQuery.txt”[/codebox]
It seems to crash in strlen, but I really doubt the problem is with the call to strlen and cOverRideName seems to be a valid string. I have the latest drivers installed and I can’t seem to find what is causing the crash. Has anyone else encountered this problem (and hopefully solved it!)?
Thank you
