Segfault when setting real component of UDDT component of UDDT
Hi Nvidia team,
this is another problem report from our test suite. A UDDT (particle_set_t) that has a UDDT (particle_t) as component gets a real component assigned but segfaults. Probably the construction of this data type has failed. The code is attached here:
main_ut.f90 (16.0 KB)
and below. The segfault (in the debugger):
Type "apropos word" to search for commands related to "word"...
Reading symbols from ./whizard_test...
(gdb) run
Starting program: /scratch/reuter/local/packages/whizard/debug/whizard-3.0.2/_build/tests/unit_tests/arsch/test_36/whizard_test
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
b
Program received signal SIGSEGV, Segmentation fault.
particles::particle_set_momentum () at main_ut.f90:315
315	       prt%p2 = p2
(gdb) bt
#0  particles::particle_set_momentum () at main_ut.f90:315
#1  0x0000000000405319 in particles::particle_set_set_momentum_all () at main_ut.f90:455
#2  0x0000000000405a92 in isr_epa_handler_uti::isr_handler_1 () at main_ut.f90:508
#3  0x0000000000405cd7 in main_ut () at main_ut.f90:518
and the code:
module kinds
  use, intrinsic :: iso_fortran_env
  use, intrinsic :: iso_c_binding
  implicit none
  private
  integer, parameter :: single    =  4   !  1.. 6 ! real32  ! c_float
  integer, parameter :: double    =  8   !  7..15 ! real64  ! c_double
  public :: single, double
  public :: default
  integer, parameter :: default           = double
 end module kinds
module constants
  use kinds, only: default
  implicit none
  private
  complex(default), parameter, public :: &
       imago = (0._default, 1._default)
  real(default), parameter, public :: &
       zero  = 0.0_default
       eps0 = epsilon (zero)
end module constants
module diagnostics
  implicit none
  private
  public :: pacify
  interface pacify
     module procedure pacify_real_default
  end interface pacify
contains
  elemental subroutine pacify_real_default (x, tolerance)
    real(default), intent(inout) :: x
    real(default), intent(in) :: tolerance
    if (abs (x) < tolerance)  x = 0._default
  end subroutine pacify_real_default
end module diagnostics
module lorentz
  use kinds, only: default, double
  use constants, only: zero, eps0
  use diagnostics
  implicit none
  private
  public :: vector3_t
  public :: vector3_null
  public :: vector3_moving
  public :: vector4_t
  public :: vector4_null
  public :: vector4_at_rest
  public :: vector4_moving
  public :: operator(*)
  public :: operator(**)
  type :: vector3_t
     real(default), dimension(3) :: p
  end type vector3_t
  type :: vector4_t
     real(default), dimension(0:3) :: p = &
        [zero, zero, zero, zero]
  end type vector4_t
  type(vector3_t), parameter :: vector3_null = &
       vector3_t ([ zero, zero, zero ])
  type(vector4_t), parameter :: vector4_null = &
       vector4_t ([ zero, zero, zero, zero ])
  interface vector3_moving
     module procedure vector3_moving_canonical
  end interface
  interface operator(*)
     module procedure prod_integer_vector3, prod_vector3_integer
     module procedure prod_real_vector3, prod_vector3_real
  end interface
     module procedure prod_vector3
  end interface
  interface vector4_moving
     module procedure vector4_moving_canonical
  end interface
     module procedure prod_real_vector4, prod_vector4_real
     module procedure prod_integer_vector4, prod_vector4_integer
  end interface
     module procedure prod_vector4
  end interface
  interface operator(**)
     module procedure power_vector4
  end interface
contains
  elemental function vector3_canonical (k) result (p)
    type(vector3_t) :: p
    integer, intent(in) :: k
    p = vector3_null
    p%p(k) = 1
  end function vector3_canonical
  elemental function vector3_moving_canonical (p, k) result(q)
    type(vector3_t) :: q
    real(default), intent(in) :: p
    q = vector3_null
    q%p(k) = p
  end function vector3_moving_canonical
  elemental function prod_real_vector3 (s, p) result (q)
    real(default), intent(in) :: s
    type(vector3_t), intent(in) :: p
    q%p = s * p%p
  end function prod_real_vector3
  elemental function prod_vector3_real (p, s) result (q)
    q%p = s * p%p
  end function prod_vector3_real
  elemental function prod_integer_vector3 (s, p) result (q)
    integer, intent(in) :: s
    q%p = s * p%p
  end function prod_integer_vector3
  elemental function prod_vector3_integer (p, s) result (q)
    q%p = s * p%p
  end function prod_vector3_integer
  elemental function prod_vector3 (p, q) result (s)
    real(default) :: s
    type(vector3_t), intent(in) :: p,q
    s = dot_product (p%p, q%p)
  elemental function vector4_canonical (k) result (p)
    type(vector4_t) :: p
    p = vector4_null
    p%p(k) = 1
  end function vector4_canonical
  elemental function vector4_at_rest (m) result (p)
    real(default), intent(in) :: m
    p = vector4_t ([ m, zero, zero, zero ])
  end function vector4_at_rest
  elemental function vector4_moving_canonical (E, p, k) result (q)
    type(vector4_t) :: q
    real(default), intent(in) :: E, p
    q = vector4_at_rest(E)
    q%p(k) = p
  end function vector4_moving_canonical
  elemental function prod_real_vector4 (s, p) result (q)
    type(vector4_t), intent(in) :: p
    q%p = s * p%p
  end function prod_real_vector4
  elemental function prod_vector4_real (p, s) result (q)
    q%p = s * p%p
  end function prod_vector4_real
  elemental function prod_integer_vector4 (s, p) result (q)
    q%p = s * p%p
  end function prod_integer_vector4
  elemental function prod_vector4_integer (p, s) result (q)
    q%p = s * p%p
  end function prod_vector4_integer
  elemental function prod_vector4 (p, q) result (s)
    real(default) :: s
    type(vector4_t), intent(in) :: p,q
    s = p%p(0)*q%p(0) - dot_product(p%p(1:), q%p(1:))
  elemental function power_vector4 (p, e) result (s)
    real(default) :: s
    integer, intent(in) :: e
    s = p * p
    if (e /= 2) then
       if (mod(e, 2) == 0) then
          s = s**(e / 2)
       else if (s >= 0) then
          s = sqrt(s)**e
       else
          s = -(sqrt(abs(s))**e)
       end if
    end if
  end function power_vector4
end module lorentz
module particles
  use lorentz
  implicit none
  private
  public :: particle_t
  public :: particle_set_t
  integer, parameter, public :: PRT_UNDEFINED = 0
  integer, parameter, public :: PRT_BEAM = -9
  integer, parameter, public :: PRT_INCOMING = 1
  integer, parameter, public :: PRT_OUTGOING = 2
  integer, parameter, public :: PRT_VIRTUAL = 4
  integer, parameter, public :: PRT_BEAM_REMNANT = 9
  type :: particle_t
     !private
     integer :: status = 0
     type(vector4_t) :: p = vector4_null
     real(default) :: p2 = 0
     type(vector4_t), allocatable :: vertex
     real(default), allocatable :: lifetime
     integer, dimension(:), allocatable :: parent
     integer, dimension(:), allocatable :: child
   contains
    generic :: init => init_particle
    procedure :: init_particle => particle_init_particle
    procedure :: reset_status => particle_reset_status
    procedure :: set_momentum => particle_set_momentum
    procedure :: set_children => particle_set_children
    procedure :: set_parents => particle_set_parents
    procedure :: get_status => particle_get_status
  end type particle_t
  type :: particle_set_t
     ! private !!!
     integer :: n_beam = 0
     integer :: n_in  = 0
     integer :: n_vir = 0
     integer :: n_out = 0
     integer :: n_tot = 0
     type(particle_t), dimension(:), allocatable :: prt
   contains
     generic :: assignment(=) => init_particle_set
     generic :: init => init_particle_set
     procedure :: init_particle_set => particle_set_init_particle_set
     procedure :: basic_init => particle_set_basic_init
     procedure :: init_direct => particle_set_init_direct
     generic :: set_momentum => set_momentum_single
     generic :: set_momentum => set_momentum_indices
     generic :: set_momentum => set_momentum_all
     procedure :: set_momentum_single => particle_set_set_momentum_single
     procedure :: set_momentum_indices => particle_set_set_momentum_indices
     procedure :: set_momentum_all => particle_set_set_momentum_all
     procedure :: reset_status => particle_set_reset_status
  end type particle_set_t
contains
  subroutine particle_init_particle (prt_out, prt_in)
    class(particle_t), intent(out) :: prt_out
    type(particle_t), intent(in) :: prt_in
    prt_out%status = prt_in%status
    prt_out%p = prt_in%p
    prt_out%p2 = prt_in%p2
    if (allocated (prt_in%vertex))  &
       allocate (prt_out%vertex, source=prt_in%vertex)
    if (allocated (prt_in%lifetime))  &
         allocate (prt_out%lifetime, source=prt_in%lifetime)
  end subroutine particle_init_particle
  elemental subroutine particle_reset_status (prt, status)
    class(particle_t), intent(inout) :: prt
    integer, intent(in) :: status
    prt%status = status
  end subroutine particle_reset_status
  elemental subroutine particle_set_momentum (prt, p, p2, on_shell)
    real(default), intent(in), optional :: p2
    logical, intent(in), optional :: on_shell
    prt%p = p
    if (present (p2)) then
       prt%p2 = p2
    else
       prt%p2 = p ** 2
    end if
  end subroutine particle_set_momentum
  subroutine particle_set_children (prt, idx)
    integer, dimension(:), intent(in) :: idx
    if (allocated (prt%child))  deallocate (prt%child)
    allocate (prt%child (count (idx /= 0)))
    prt%child = pack (idx, idx /= 0)
  end subroutine particle_set_children
  subroutine particle_set_parents (prt, idx)
    if (allocated (prt%parent))  deallocate (prt%parent)
    allocate (prt%parent (count (idx /= 0)))
    prt%parent = pack (idx, idx /= 0)
  end subroutine particle_set_parents
  elemental function particle_get_status (prt) result (status)
    integer :: status
    class(particle_t), intent(in) :: prt
    status = prt%status
  end function particle_get_status
  subroutine particle_set_init_particle_set (pset_out, pset_in)
    class(particle_set_t), intent(out) :: pset_out
    type(particle_set_t), intent(in) :: pset_in
    integer :: i
    pset_out%n_beam = pset_in%n_beam
    pset_out%n_in   = pset_in%n_in
    pset_out%n_vir  = pset_in%n_vir
    pset_out%n_out  = pset_in%n_out
    pset_out%n_tot  = pset_in%n_tot
    if (allocated (pset_in%prt)) then
       allocate (pset_out%prt (size (pset_in%prt)))
       do i = 1, size (pset_in%prt)
          pset_out%prt(i) = pset_in%prt(i)
       end do
    end if
  end subroutine particle_set_init_particle_set
  subroutine particle_set_basic_init (particle_set, n_beam, n_in, n_vir, n_out)
    class(particle_set_t), intent(out) :: particle_set
    integer, intent(in) :: n_beam, n_in, n_vir, n_out
    particle_set%n_beam = n_beam
    particle_set%n_in = n_in
    particle_set%n_vir = n_vir
    particle_set%n_out = n_out
    particle_set%n_tot = n_beam + n_in + n_vir + n_out
    allocate (particle_set%prt (particle_set%n_tot))
  end subroutine particle_set_basic_init
  subroutine particle_set_init_direct (particle_set, &
       n_beam, n_in, n_rem, n_vir, n_out, pdg)
    integer, intent(in) :: n_in
    integer, intent(in) :: n_rem
    integer, intent(in) :: n_vir
    integer, intent(in) :: n_out
    integer, dimension(:), intent(in) :: pdg
    integer :: i, k, n
    call particle_set%basic_init (n_beam, n_in, n_rem+n_vir, n_out)
    n = 0
    call particle_set%prt(n+1:n+n_beam)%reset_status (PRT_BEAM)
    do i = n+1, n+n_beam
       call particle_set%prt(i)%set_children &
            ([(k, k=i+n_beam, n+n_beam+n_in+n_rem, 2)])
    end do
    n = n + n_beam
    call particle_set%prt(n+1:n+n_in)%reset_status (PRT_INCOMING)
    do i = n+1, n+n_in
       if (n_beam > 0) then
          call particle_set%prt(i)%set_parents &
               ([i-n_beam])
       end if
            ([(k, k=n+n_in+n_rem+1, n+n_in+n_rem+n_vir+n_out)])
    end do
    n = n + n_in
    call particle_set%prt(n+1:n+n_rem)%reset_status (PRT_BEAM_REMNANT)
    do i = n+1, n+n_rem
               ([i-n_in-n_beam])
       end if
    end do
    n = n + n_rem
    call particle_set%prt(n+1:n+n_vir)%reset_status (PRT_VIRTUAL)
    do i = n+1, n+n_vir
            ([(k, k=n-n_rem-n_in+1, n-n_rem)])
    end do
    n = n + n_vir
    call particle_set%prt(n+1:n+n_out)%reset_status (PRT_OUTGOING)
    do i = n+1, n+n_out
            ([(k, k=n-n_vir-n_rem-n_in+1, n-n_vir-n_rem)])
    end do
  end subroutine particle_set_init_direct
  subroutine particle_set_set_momentum_single &
       (particle_set, i, p, p2, on_shell)
    class(particle_set_t), intent(inout) :: particle_set
    integer, intent(in) :: i
    call particle_set%prt(i)%set_momentum (p, p2, on_shell)
  end subroutine particle_set_set_momentum_single
  subroutine particle_set_set_momentum_indices &
       (particle_set, indices, p, p2, on_shell)
    integer, dimension(:), intent(in) :: indices
    type(vector4_t), dimension(:), intent(in) :: p
    real(default), dimension(:), intent(in), optional :: p2
    integer :: i
       do i = 1, size (indices)
          call particle_set%prt(indices(i))%set_momentum (p(i), p2(i), on_shell)
       end do
    else
          call particle_set%prt(indices(i))%set_momentum &
               (p(i), on_shell=on_shell)
       end do
    end if
  end subroutine particle_set_set_momentum_indices
  subroutine particle_set_set_momentum_all (particle_set, p, p2, on_shell)
    call particle_set%prt%set_momentum (p, p2, on_shell)
  end subroutine particle_set_set_momentum_all
  subroutine particle_set_reset_status (particle_set, index, status)
    integer, dimension(:), intent(in) :: index
    integer :: i
    if (allocated (particle_set%prt)) then
       do i = 1, size (index)
          call particle_set%prt(index(i))%reset_status (status)
       end do
    end if
    particle_set%n_beam  = &
         count (particle_set%prt%get_status () == PRT_BEAM)
    particle_set%n_in  = &
         count (particle_set%prt%get_status () == PRT_INCOMING)
    particle_set%n_out = &
         count (particle_set%prt%get_status () == PRT_OUTGOING)
    particle_set%n_vir = particle_set%n_tot &
         - particle_set%n_beam - particle_set%n_in - particle_set%n_out
  end subroutine particle_set_reset_status
end module particles
module isr_epa_handler_uti
  use lorentz, only: vector4_t, vector4_moving, operator(*)
  use particles, only: particle_set_t
  implicit none
  private
  public :: isr_handler_1
contains
  subroutine isr_handler_1 (u)
    integer, intent(in) :: u
    type(particle_set_t) :: pset
    type(vector4_t), dimension(8) :: p
    real(default) :: sqrts
    real(default), dimension(2) :: x, xb
    real(default) :: probability
    call pset%init_direct (n_beam = 2, n_in = 2, n_rem = 2, n_vir = 0, n_out = 2, &
         pdg = [11, -11, 11, -11, 22, 22, 13, -13])
    sqrts = 100._default
    x = [0.6_default, 0.9_default]
    xb= 1 - x
    p(1) = vector4_moving (sqrts/2, sqrts/2, 3)
    p(2) = vector4_moving (sqrts/2,-sqrts/2, 3)
    p(3:4) = x * p(1:2)
    p(5:6) = xb  * p(1:2)
    p(7:8) = p(3:4)
    call pset%set_momentum (p, on_shell = .false.)
  end subroutine isr_handler_1
end module isr_epa_handler_uti
program main_ut
  use isr_epa_handler_uti, only: isr_handler_1
  implicit none
  call isr_handler_1 (6)
end program main_ut
Thanks Juergen. I added TPR #33515 and sent it to engineering for investigation.
-Mat
The main collection of issues is here:
