i’ve got an application build with boost-1.37 (among other libraries). it appears to run, but dies when the dtors are called.
Is there a problem with the order of the shared libraries? i see some libc and libpgc which could conflict?
host > app
app runs nicely and gives results equivalent to intel and g++
then…
============= TEST COMPLETE ===========
C++ runtime abort: terminate() called by the exception handling mechanism
Abort
host> ldd /local/mcatk/users/sdnolen/workspace/obj/pgi-opt/src/Interface/fi_test/Interface_fi_tester_run
libboost_filesystem-mt-1_37-pgi10.so => /local/mcatk/packages/lib/libboost_filesystem-mt-1_37-pgi10.so (0x0000002a95557000)
libboost_signals-mt-1_37-pgi10.so => /local/mcatk/packages/lib/libboost_signals-mt-1_37-pgi10.so (0x0000002a956c7000)
libboost_mpi-mt-1_37-pgi10.so => /local/mcatk/packages/lib/libboost_mpi-mt-1_37-pgi10.so (0x0000002a9583e000)
libboost_program_options-mt-1_37-pgi10.so => /local/mcatk/packages/lib/libboost_program_options-mt-1_37-pgi10.so (0x0000002a95aaf000)
libboost_system-mt-1_37-pgi10.so => /local/mcatk/packages/lib/libboost_system-mt-1_37-pgi10.so (0x0000002a95d94000)
libboost_serialization-mt-1_37-pgi10.so => /local/mcatk/packages/lib/libboost_serialization-mt-1_37-pgi10.so (0x0000002a95ea0000)
libloki-pgi.so.0.1.7 => /local/mcatk/packages/lib/libloki-pgi.so.0.1.7 (0x0000002a96374000)
libtbb.so.2 => /local/mcatk/packages/src/tbb-2.0.17/build/linux_em64t_pgi_cc4.3.3_libc2.3.4_kernel2.6.9_release/libtbb.so.2 (0x0000002a9649a000)
libpthread.so.0 => /lib64/tls/libpthread.so.0 (0x0000003f9d100000)
libmpi_cxx.so.0 => /local/mcatk/packages/lib/libmpi_cxx.so.0 (0x0000002a965ec000)
libmpi.so.0 => /local/mcatk/packages/lib/libmpi.so.0 (0x0000002a96707000)
libopen-rte.so.0 => /local/mcatk/packages/lib/libopen-rte.so.0 (0x0000002a968b0000)
libopen-pal.so.0 => /local/mcatk/packages/lib/libopen-pal.so.0 (0x0000002a969f8000)
libdl.so.2 => /lib64/libdl.so.2 (0x0000003f9cb00000)
libnsl.so.1 => /lib64/libnsl.so.1 (0x0000003fa4800000)
libutil.so.1 => /lib64/libutil.so.1 (0x0000003f9ef00000)
libm.so.6 => /lib64/tls/libm.so.6 (0x0000003f9c900000)
libnuma.so => /usr/lib64/libnuma.so (0x0000003f9c400000)
libpgbind.so => /opt/local/vendor/pgi-10.1/10.1/share_objects/lib64/libpgbind.so (0x0000002a96b6f000)
libstd.so => /opt/local/vendor/pgi-10.1/linux86-64/10.1/libso/libstd.so (0x0000002a96c71000)
libC.so => /opt/local/vendor/pgi-10.1/linux86-64/10.1/libso/libC.so (0x0000002a96edb000)
libpgc.so => /opt/local/vendor/pgi-10.1/linux86-64/10.1/libso/libpgc.so (0x0000002a96ff3000)
libc.so.6 => /lib64/tls/libc.so.6 (0x0000003f9c600000)
librt.so.1 => /lib64/tls/librt.so.1 (0x0000003fa1000000)
/lib64/ld-linux-x86-64.so.2 (0x0000003f9c200000)
libstdc++.so.6 => /local/mcatk/packages/lib/…/lib64/libstdc++.so.6 (0x0000002a97149000)
libgcc_s.so.1 => /local/mcatk/packages/lib/…/lib64/libgcc_s.so.1 (0x0000002a97354000)
the only library not build specifically with PGI was the openmpi one, but we are only using the c-interface from this (or at least boost is)
