I’m building an autonomous off-road navigation system using SegFormer-B2 trained on Yamaha-CMU Off-Road (YCOR), with approximately 57.4% recorded validation mIoU.
On Jetson AGX + ZED 2i, my TensorRT FP16 engine runs at 20–30 FPS with a 512×512 model input. I’m targeting 40–50 FPS now, and 60+ FPS for a future ZED X setup, while maintaining useful accuracy.
I’ve trained Fast-SCNN and PIDNet-S on the same dataset. They run faster, but their segmentation quality hasn’t matched SegFormer.
My main accuracy issues are:
Close-up obstacles sometimes change to smooth trail.
Beams, wall edges, and pillars are sometimes classified as traversable paths.
Unrelated class patches appear on otherwise clear terrain.
The model currently uses RGB only.
What would you recommend for improving speed and accuracy—distillation, INT8, better training data, alternative models, or combining segmentation with stereo depth?
Practical experience, benchmarks, and implementation references would be very helpful.
Sorry for the late update.
Do you still need help with this issue? Have you tried the INT8 inference?
