Hi, I trained a DetectNet following Two Days to a Demo (DIGITS) instruments.
Then, downloaded the model and tried to run detectnet-console on Jetson Xavier Agx(# R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t186ref, EABI: aarch64, DATE: Fri Jun 26 04:34:27 UTC 2020) and get following error:
detectnet-console ./desk.jpg inf.jpg --prototxt=./deploy.prototxt --model=./snapshot_iter_23000.caffemodel
[video] created imageLoader from file:///home/zhoi/ai/deskm/./desk.jpg
imageLoader video options:
-- URI: file:///home/zhoi/ai/deskm/./desk.jpg
- protocol: file
- extension: jpg
-- deviceType: file
-- ioType: input
-- codec: unknown
-- width: 0
-- height: 0
-- frameRate: 0.000000
-- bitRate: 0
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
[video] created imageWriter from file:///home/zhoi/ai/deskm/inf.jpg
imageWriter video options:
-- URI: file:///home/zhoi/ai/deskm/inf.jpg
- protocol: file
- extension: jpg
-- deviceType: file
-- ioType: output
-- codec: unknown
-- width: 0
-- height: 0
-- bitRate: 0
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
detectNet -- loading detection network model from:
-- prototxt ./deploy.prototxt
-- model ./snapshot_iter_23000.caffemodel
-- input_blob 'data'
-- output_cvg 'coverage'
-- output_bbox 'bboxes'
-- mean_pixel 0.000000
-- mean_binary NULL
-- class_labels NULL
-- threshold 0.500000
-- batch_size 1
[TRT] TensorRT version 7.1.3
[TRT] loading NVIDIA plugins...
[TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[TRT] Registered plugin creator - ::NMS_TRT version 1
[TRT] Registered plugin creator - ::Reorg_TRT version 1
[TRT] Registered plugin creator - ::Region_TRT version 1
[TRT] Registered plugin creator - ::Clip_TRT version 1
[TRT] Registered plugin creator - ::LReLU_TRT version 1
[TRT] Registered plugin creator - ::PriorBox_TRT version 1
[TRT] Registered plugin creator - ::Normalize_TRT version 1
[TRT] Registered plugin creator - ::RPROI_TRT version 1
[TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[TRT] Could not register plugin creator - ::FlattenConcat_TRT version 1
[TRT] Registered plugin creator - ::CropAndResize version 1
[TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[TRT] Registered plugin creator - ::Proposal version 1
[TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[TRT] Registered plugin creator - ::Split version 1
[TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[TRT] detected model format - caffe (extension '.caffemodel')
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16, INT8
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file ./snapshot_iter_23000.caffemodel.1.1.7103.GPU.FP16.engine
[TRT] loading network plan from engine cache... ./snapshot_iter_23000.caffemodel.1.1.7103.GPU.FP16.engine
[TRT] device GPU, loaded ./snapshot_iter_23000.caffemodel
[TRT] Deserialize required 2705619 microseconds.
[TRT]
[TRT] CUDA engine context initialized on device GPU:
[TRT] -- layers 74
[TRT] -- maxBatchSize 1
[TRT] -- workspace 0
[TRT] -- deviceMemory 158651392
[TRT] -- bindings 3
[TRT] binding 0
-- index 0
-- name 'data'
-- type FP32
-- in/out INPUT
-- # dims 3
-- dim #0 3 (SPATIAL)
-- dim #1 1088 (SPATIAL)
-- dim #2 1920 (SPATIAL)
[TRT] binding 1
-- index 1
-- name 'coverage'
-- type FP32
-- in/out OUTPUT
-- # dims 3
-- dim #0 1 (SPATIAL)
-- dim #1 68 (SPATIAL)
-- dim #2 120 (SPATIAL)
[TRT] binding 2
-- index 2
-- name 'bboxes'
-- type FP32
-- in/out OUTPUT
-- # dims 3
-- dim #0 4 (SPATIAL)
[TRT]
[TRT] binding to input 0 data binding index: 0
[TRT] binding to input 0 data dims (b=1 c=3 h=1088 w=1920) size=25067520
[TRT] binding to output 0 coverage binding index: 1
[TRT] binding to output 0 coverage dims (b=1 c=1 h=68 w=120) size=32640
[TRT] binding to output 1 bboxes binding index: 2
[TRT] binding to output 1 bboxes dims (b=1 c=4 h=68 w=120) size=130560
[TRT]
[TRT] device GPU, ./snapshot_iter_23000.caffemodel initialized.
[TRT] detectNet -- number object classes: 1
[TRT] detectNet -- maximum bounding boxes: 8160
[image] loaded './desk.jpg' (1920x1080, 3 channels)
I also tried the model and same command on Jetson Nano(# R32 (release), REVISION: 4.2, GCID: 20074772, BOARD: t210ref, EABI: aarch64, DATE: Thu Apr 9 01:22:12 UTC 2020), and everything goes well.
What’s wrong with my AGX board?
BTW. difference between agx and nano in jetson-inference install stage: I installed data sets on nano while agx nothing, I’m not sure whether it matters in following installation.
