I encounter with a problem when I am trying to initialize a large size zero arrays (x(2, 2800, 1600000)). I make it an allocatable array but still the segmentation fault message appears.
Here is my code:
program test
integer(kind=1), allocatable :: x(:, :, :)
allocate(x(2, 2800, 1600000))
x = 0_1
end program
I’ve tried ulimit -s unlimited but it didn’t work. I am working on a workstation and I suppose it should have larger memory than 8.34GB. Could anyone help with this?
For large dynamically allocated arrays (>2GB), you need to compile with the “-Mlarge_arrays” or “-mcmodel=medium” options. Since there’s extra overhead with managing larger arrays, we don’t enable this support by default.
FYI - Mlarge_arrays switch tells the compiler to calculate its
array-index-to-byte-offset math using 64-bit integers instead of 32-bit.
The offset for x(1,1500,1400000) would be
115001400000*4(bytes per array element) which could go beyond
32-bit limits.
-mcmodel=medium
means to convert to an object file format that accepts large statically
allocated arrays. It usually runs slower, so allocate the big arrays
dynamically and avoid -mcmodel=medium, but use -Mlarge_arrays
only.
