I’m using Free PGI under OS X 10.7.5 (with XCode 4.6.3). The output from pgfortran -v is
pgfortran 14.3-0 64-bit target on Apple OS/X developer $INFOTPVAL
The Portland Group - PGI Compilers and Tools
Copyright © 2014, NVIDIA CORPORATION. All rights reserved
The following code triggers a segmentation fault after write (,) “END SUBROUTINE”, but before write (,) “RETURNED OK”
module my_module
implicit none
type :: my_type
type (my_type) , pointer :: next => null()
contains
procedure , pass :: f
end type
contains
subroutine f( obj )
class (my_type) , intent (inout) :: obj
end subroutine
subroutine process( obj )
type (my_type) , intent (inout) , target :: obj
type (my_type) , pointer :: test => null()
type (my_type) , pointer :: tmp => null()
write (*,*) associated( obj % next )
test => obj % next
write (*,*) associated( test )
call test % f()
write(*,*) "END SUBROUTINE"
end subroutine
end module
program main
use my_module
implicit none
type (my_type) :: obj
allocate( obj % next )
call process( obj )
write (*,*) "RETURNED OK"
end program
I can’t see any reason for this, and the problem does not occur if gfortran or nagfor is used. Therefore I think this is a bug in pgfortran.
