I customize a plugin named “detectOutPut” and use the existing plugins from TensorRT 5.0.
I do it just as following:
// create pluginfactory
nvinfer1::IPlugin* PluginFactory::createPlugin(const char* layerName, const nvinfer1::Weights* weights, int nbWeights)
createPlugin();
// do it
main.cpp
initLibNvInferPlugins(&gLogger.getTRTLogger(), “”);
parser->setPluginFactoryExt(pluginFactory);
engine = builder->buildCudaEngine(*network);
it run inoto " Segmentation fault (core dumped) "
does I do it right ? if not, how should I do. can you give me some samples for this case.
