config_infer_primary_yoloV3.txt (3.4 KB) test.txt (8.1 KB)
Here are the files. Here’s some more info: I tried clearing gstreamer cache. There are other processes running on the AGX too: 5 python processes, kafka broker and mongod. Mongo’s dbpath is set to an external SDcard but its mounted inside the deepstream-test5 folder.
Still having the same issue:
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8555/ds-test ***
Opening in BLOCKING MODE
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_nvdcf.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
[NvDCF] Initialized
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
Deserialize yoloLayerV3 plugin: yolo_83
Deserialize yoloLayerV3 plugin: yolo_95
Deserialize yoloLayerV3 plugin: yolo_107
0:00:04.761050590 21867 0x5565f2c440 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test5/configs/model_b8_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 4
0 INPUT kFLOAT data 3x608x608
1 OUTPUT kFLOAT yolo_83 255x19x19
2 OUTPUT kFLOAT yolo_95 255x38x38
3 OUTPUT kFLOAT yolo_107 255x76x76
0:00:04.761338188 21867 0x5565f2c440 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test5/configs/model_b8_gpu0_int8.engine
0:00:04.828050418 21867 0x5565f2c440 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test5/configs/config_infer_primary_yoloV3.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:181>: Pipeline ready
Fri Apr 9 06:40:03 2021
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
** INFO: <bus_callback:167>: Pipeline running
H264: Profile = 66, Level = 0
WARNING; playback mode used with URI [rtsp://***:***@192.168.1.202/cam0_0] not conforming to timestamp format; check README; using system-time
WARNING; playback mode used with URI [rtsp://***:***@192.168.1.206/cam0_0] not conforming to timestamp format; check README; using system-time
WARNING; playback mode used with URI [rtsp://***:***@192.168.1.204/cam0_0] not conforming to timestamp format; check README; using system-time
WARNING; playback mode used with URI [rtsp://***:***@192.168.1.205/cam0_0] not conforming to timestamp format; check README; using system-time
WARNING; playback mode used with URI [rtsp://***:***@192.168.1.203/cam0_0] not conforming to timestamp format; check README; using system-time
Fri Apr 9 06:40:08 2021
**PERF: 8.10 (7.89) 7.25 (7.09) 8.10 (7.89) 9.39 (9.15) 8.56 (8.39)
Fri Apr 9 06:40:13 2021
**PERF: 9.32 (8.62) 9.17 (8.19) 9.12 (8.51) 9.08 (8.81) 9.17 (8.73)
Fri Apr 9 06:40:18 2021
**PERF: 9.14 (8.89) 9.14 (8.63) 9.14 (8.82) 9.04 (9.11) 8.95 (8.89)
Fri Apr 9 06:40:23 2021
**PERF: 9.27 (8.92) 9.04 (8.73) 8.84 (8.82) 8.84 (9.03) 8.84 (8.87)
Fri Apr 9 06:40:28 2021
**PERF: 8.93 (8.98) 8.55 (8.70) 8.75 (8.81) 8.95 (9.02) 8.95 (8.90)
Fri Apr 9 06:40:33 2021
**PERF: 9.38 (9.02) 9.58 (8.82) 9.58 (8.91) 9.58 (9.09) 9.58 (8.98)
Fri Apr 9 06:40:38 2021
**PERF: 8.89 (8.93) 9.40 (8.85) 9.52 (8.93) 9.40 (9.07) 9.40 (8.99)
Fri Apr 9 06:40:43 2021
**PERF: 9.38 (9.06) 9.30 (8.97) 9.19 (9.04) 9.30 (9.17) 9.30 (9.09)
Fri Apr 9 06:40:48 2021
**PERF: 9.01 (9.03) 9.01 (8.95) 9.01 (9.01) 8.68 (9.08) 9.01 (9.06)
Fri Apr 9 06:40:53 2021
**PERF: 9.35 (9.07) 9.35 (9.00) 9.35 (9.05) 9.47 (9.13) 9.15 (9.07)
Fri Apr 9 06:40:58 2021
**PERF: 9.19 (9.10) 9.19 (9.04) 9.19 (9.08) 9.19 (9.16) 8.99 (9.08)
Fri Apr 9 06:41:03 2021
**PERF: 9.24 (9.11) 9.04 (9.03) 8.63 (9.04) 8.83 (9.13) 9.04 (9.08)
Fri Apr 9 06:41:08 2021
**PERF: 8.61 (9.05) 8.61 (8.98) 9.02 (9.02) 9.02 (9.10) 9.02 (9.05)
Fri Apr 9 06:41:13 2021
**PERF: 9.55 (9.09) 9.55 (9.03) 9.55 (9.06) 9.55 (9.14) 9.55 (9.09)
Fri Apr 9 06:41:18 2021
**PERF: 9.18 (9.09) 9.15 (9.04) 9.35 (9.09) 8.95 (9.14) 9.15 (9.11)
Fri Apr 9 06:41:23 2021
**PERF: 9.32 (9.12) 9.35 (9.06) 9.15 (9.09) 9.15 (9.13) 9.36 (9.12)
Fri Apr 9 06:41:28 2021
**PERF: 9.04 (9.12) 9.04 (9.07) 9.04 (9.10) 9.24 (9.15) 8.65 (9.10)
Fri Apr 9 06:41:33 2021
**PERF: 9.39 (9.12) 9.07 (9.06) 9.07 (9.08) 9.07 (9.13) 9.27 (9.09)
Fri Apr 9 06:41:38 2021
**PERF: 9.34 (9.14) 9.25 (9.07) 9.06 (9.09) 9.25 (9.14) 9.25 (9.11)
Fri Apr 9 06:41:43 2021
**PERF: 8.65 (9.11) 8.85 (9.05) 9.06 (9.07) 9.06 (9.13) 9.06 (9.10)
Fri Apr 9 06:41:48 2021
**PERF: 8.98 (9.11) 9.17 (9.07) 9.54 (9.09) 9.17 (9.14) 9.17 (9.11)
Fri Apr 9 08:58:49 2021
**PERF: 8.80 (8.90) 8.80 (8.89) 9.00 (8.90) 8.39 (8.90) 8.59 (8.90)
Fri Apr 9 08:58:54 2021
**PERF: 9.15 (8.90) 8.95 (8.89) 9.15 (8.90) 9.15 (8.90) 9.15 (8.90)
Fri Apr 9 08:58:59 2021
**PERF: 9.11 (8.90) 8.83 (8.89) 8.83 (8.90) 9.04 (8.90) 9.04 (8.90)
Fri Apr 9 08:59:04 2021
**PERF: 8.65 (8.90) 9.34 (8.90) 8.73 (8.90) 9.13 (8.90) 9.13 (8.90)
Fri Apr 9 08:59:09 2021
**PERF: 9.06 (8.90) 8.86 (8.90) 9.06 (8.90) 9.06 (8.90) 8.86 (8.90)
Segmentation fault
