I want to decode 4 video streams, using nveglglessink, shown above the hdmi output.
Each thread of video decoding pipeline is like this
Appsrc-> h265parse-> omxh265dec-> nvvidconv-> textoverlay-> nveglglessink
The program can be normal decoding and display, but when I need to turn off a video decoding, I would like to use gst_element_set_state (pipeline, GST_STATE_NULL) function to completely close the way to decode the image, restore back to the previous black screen status.
However, by setting the state of the entire pipeline, often decoding is stopped, but the last frame is displayed on the display, not returned to the black screen state.
In order to solve this problem, I first set the state of nveglglessink to NULL, nveglglessink state is set to NULL, the window can disappear. And then set the status of the pipeline.
Gst_element_set_state (obj-> display, GST_STATE_NULL);
Gst_element_set_state (obj-> pipeline, GST_STATE_NULL);
Gst_object_unref (GST_OBJECT (obj-> pipeline));
When I need to open this video decode, I’ll recreate the pipeline again.
I was configuring the parameters of nveglglessink link:
display = gst_element_factory_make("nveglglessink","display");
g_object_set (G_OBJECT (display), "max-lateness", 10000000, NULL);
g_object_set (G_OBJECT (display), "ts-offset", 0, NULL);
g_object_set (G_OBJECT (display), "window-x", params_inside->window_x, NULL);
g_object_set (G_OBJECT (display), "window-y", params_inside->window_y, NULL);
g_object_set (G_OBJECT (display), "window-width", params_inside->window_width, NULL);
g_object_set (G_OBJECT (display), "window-height", params_inside->window_height, NULL);
g_object_set (G_OBJECT (display), "force-aspect-ratio", TRUE, NULL);
However, when I create and destroy the pipeline several times, when I call gst_element_set_state (obj-> display, GST_STATE_NULL), a Segmentation fault occurs.
Use gdb to print segment error messages as follows
X Error of failed request: BadWindow (invalid Window parameter)
Major opcode of failed request: 4 (X_DestroyWindow)
Resource id in failed request: 0x400001
Serial number of failed request: 17
Current serial number in output stream: 18
NvEglHandle: Unfreed handle upon egl deinit: type=2 refcnt=2
NvEglHandle: Unfreed handle upon egl deinit: type=1 refcnt=1
Thread 7 "core" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7f9e4d91e0 (LWP 8051)]
0x0000007f7e99cb50 in _nv018glsi () from /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glsi.so.24.2.1
(gdb) bt
#0 0x0000007f7e99cb50 in _nv018glsi () from /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glsi.so.24.2.1
#1 0x0000007f695f45d4 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.24.2.1
#2 0x0000007f695ddf98 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.24.2.1
#3 0x0000007f695de154 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.24.2.1
#4 0x0000007f696b1bf0 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.24.2.1
#5 0x0000007f696b1e30 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.24.2.1
#6 0x0000007f696773c4 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.24.2.1
#7 0x0000007f69677728 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.24.2.1
#8 0x0000007f69648f18 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.24.2.1
#9 0x0000007f6960b5a8 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.24.2.1
#10 0x0000007f695df898 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.24.2.1
#11 0x0000007f695f1f0c in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.24.2.1
#12 0x0000007f7c045e20 in ?? () from /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv2.so.2
#13 0x0000007f7ea4f934 in ?? () from /usr/lib/aarch64-linux-gnu/tegra-egl/libEGL_nvidia.so.0
#14 0x0000007f7eaaa99c in ?? () from /usr/lib/aarch64-linux-gnu/tegra-egl/libEGL_nvidia.so.0
#15 0x0000007f7ea48958 in ?? () from /usr/lib/aarch64-linux-gnu/tegra-egl/libEGL_nvidia.so.0
#16 0x0000007fb7fe0098 in _dl_fini () at dl-fini.c:235
#17 0x0000007fb78b2ed8 in __run_exit_handlers (status=1, listp=0x7fb79bf4d8 <__exit_funcs>, run_list_atexit=run_list_atexit@entry=true) at exit.c:82
#18 0x0000007fb78b2f00 in __GI_exit (status=<optimized out>) at exit.c:104
#19 0x0000007f7c328294 in _XDefaultError () from /usr/lib/aarch64-linux-gnu/libX11.so.6
#20 0x0000007f7c3283d4 in _XError () from /usr/lib/aarch64-linux-gnu/libX11.so.6
#21 0x0000007f7c3251d4 in ?? () from /usr/lib/aarch64-linux-gnu/libX11.so.6
#22 0x0000007f98336ba0 in ?? ()
Backtrace stopped: previous frame inner to this frame (corrupt stack?)
(gdb) bt full
No symbol table info available.
array = 0x7f7eb08008
i = 1
l = 0x7f981f6db0
maps = 0x7f9e4d80c0
i = 15
l = <optimized out>
nmaps = 89
nloaded = <optimized out>
ns = 0
do_audit = 127
__PRETTY_FUNCTION__ = "_dl_fini"
atfct = <optimized out>
onfct = <optimized out>
cxafct = <optimized out>
No locals.
Excuse me, is my method of using it incorrect? Or plug-in problem.
This question bothers me for days, please help me, thank you!
