Jetson AGX Xavier
• DeepStream Version
5.1
4.5.1
• TensorRT Version
7.1.3.0
Segmentation fault on multiple camera of “nvv4l2decoder”
Due to Nvidia employee mentioned:
The nvjpegdec plugin is not supported in DeepStream SDK Using nvv4l2decoder(mjpeg=1) to decode mjpeg camera stream.
Working pipeline:
Single Camera on HW Accel decoding:
v4l2src -> capsfilter(image/jpeg) -> jpegparse -> nvv4l2decoder(mjpeg=1) -> nvvideoconvert -> capsfilter(caps=video/x-raw(memory:NVMM)) -> nvstreammux -> nvinfer -> nvmultistreamtiler -> nvdsosd -> nvegltransform -> nveglglessink
Multi-Cameras on software decoding:
v4l2src(source=0) -> capsfilter(image/jpeg) -> jpegdec -> nvvideoconvert -> capsfilter(caps=video/x-raw(memory:NVMM)) -> nvstreammux
v4l2src(source=1) -> capsfilter(image/jpeg) -> jpegdec -> nvvideoconvert -> capsfilter(caps=video/x-raw(memory:NVMM)) -> nvstreammux
Segmentation fault pipeline:
Multi-Cameras on HW Accel decoding:
v4l2src(source=0) -> capsfilter(image/jpeg) -> jpegparse -> nvv4l2decoder(mjpeg=1) -> nvvideoconvert -> capsfilter(caps=video/x-raw(memory:NVMM)) -> nvstreammux
v4l2src(source=1) -> capsfilter(image/jpeg) -> jpegparse -> nvv4l2decoder(mjpeg=1) -> nvvideoconvert -> capsfilter(caps=video/x-raw(memory:NVMM)) -> nvstreammux
#!/usr/bin/env python3
import time
import math
import sys
import gi
gi.require_version('Gst', '1.0')
from gi.repository import GObject, Gst
WIDTH = 1920
HEIGHT = 1080
HW_ACCEL = True
# HW_ACCEL = False
def bus_call(bus, message, loop):
t = message.type
if t == Gst.MessageType.EOS:
sys.stdout.write("End-of-stream\n")
loop.quit()
elif t==Gst.MessageType.WARNING:
err, debug = message.parse_warning()
sys.stderr.write("Warning: %s: %s\n" % (err, debug))
elif t == Gst.MessageType.ERROR:
err, debug = message.parse_error()
sys.stderr.write("Error: %s: %s\n" % (err, debug))
loop.quit()
return True
def create_source_bin(index):
camera = '/dev/video%d' % index
print(camera)
nbin=Gst.Bin.new("source-bin-%d" % index)
if not nbin:
sys.stderr.write(" Unable to create source bin")
source = Gst.ElementFactory.make("v4l2src", "usb-cam-source")
if not source:
sys.stderr.write(" Unable to create source")
source.set_property('device', camera)
source.set_property('io-mode', 2)
nbin.add(source)
caps_v4l2src = Gst.ElementFactory.make("capsfilter", "v4l2src_caps")
if not caps_v4l2src:
sys.stderr.write("Could not create caps_v4l2src")
caps_v4l2src.set_property('caps', Gst.Caps.from_string("image/jpeg, width=%d, height=%d, framerate=30/1" % (WIDTH, HEIGHT)))
nbin.add(caps_v4l2src)
if HW_ACCEL:
jpegparse = Gst.ElementFactory.make("jpegparse", "jpeg-parser")
if not jpegparse:
sys.stderr.write(" Unable to create jpeg parser")
nbin.add(jpegparse)
nvv4l2decoder = Gst.ElementFactory.make("nvv4l2decoder", "nvv4l2decoder")
if not nvv4l2decoder:
sys.stderr.write(" Unable to create nvv4l2decoder")
nvv4l2decoder.set_property('mjpeg', 1)
nbin.add(nvv4l2decoder)
else:
jpegdec = Gst.ElementFactory.make("jpegdec", "jpegdec")
if not jpegdec:
sys.stderr.write(" Unable to create jpegdec")
nbin.add(jpegdec)
nvvidconvsrc = Gst.ElementFactory.make("nvvideoconvert", "nvvideoconvert")
if not nvvidconvsrc:
sys.stderr.write(" Unable to create nvvideoconvert")
nbin.add(nvvidconvsrc)
caps_vidconvsrc = Gst.ElementFactory.make("capsfilter", "capsfilter")
if not caps_vidconvsrc:
sys.stderr.write(" Unable to create capsfilter")
caps_vidconvsrc.set_property('caps', Gst.Caps.from_string("video/x-raw(memory:NVMM)"))
nbin.add(caps_vidconvsrc)
source.link(caps_v4l2src)
caps_v4l2src.link(videorate)
if HW_ACCEL:
videorate.link(jpegparse)
jpegparse.link(nvv4l2decoder)
nvv4l2decoder.link(nvvidconvsrc)
else:
videorate.link(jpegdec)
jpegdec.link(nvvidconvsrc)
nvvidconvsrc.link(videoscale)
videoscale.link(caps_vidconvsrc)
srcpad = caps_vidconvsrc.get_static_pad("src")
bin_pad=nbin.add_pad(Gst.GhostPad.new("src",srcpad))
if not bin_pad:
sys.stderr.write(" Failed to add ghost pad in source bin")
return None
return nbin
def run(number_sources):
GObject.threads_init()
Gst.init(None)
pipeline = Gst.Pipeline()
if not pipeline:
sys.stderr.write(" Unable to create Pipeline")
streammux = Gst.ElementFactory.make("nvstreammux", "streammux")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux")
streammux.set_property('width', WIDTH)
streammux.set_property('height', HEIGHT)
streammux.set_property('batch-size', number_sources)
streammux.set_property('batched-push-timeout', 1000 * 1000) # 1000ms
streammux.set_property('live-source', 1)
pipeline.add(streammux)
pgie = Gst.ElementFactory.make("nvinfer", "pgie")
if not pgie:
sys.stderr.write(" Unable to create pgie")
pgie.set_property('config-file-path', "config.txt")
pgie.set_property("batch-size", number_sources)
pipeline.add(pgie)
caps_filter = Gst.ElementFactory.make("capsfilter", "caps_filter")
if not caps_filter:
caps_filter.set_property('caps', Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA"))
pipeline.add(caps_filter)
tiler = Gst.ElementFactory.make("nvmultistreamtiler", "tiler")
if not tiler:
sys.stderr.write(" Unable to create tiler")
tiler_rows = int(math.sqrt(number_sources))
tiler_columns = int(math.ceil((1.0 * number_sources) / tiler_rows))
tiler.set_property("rows", tiler_rows)
tiler.set_property("columns", tiler_columns)
tiler.set_property("width", WIDTH)
tiler.set_property("height", HEIGHT)
pipeline.add(tiler)
nvosd = Gst.ElementFactory.make("nvdsosd", "nvosd")
if not nvosd:
sys.stderr.write(" Unable to create nvosd")
pipeline.add(nvosd)
transform = Gst.ElementFactory.make("nvegltransform", "transform")
if not transform:
sys.stderr.write(" Unable to create transform")
pipeline.add(transform)
sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
if not sink:
sys.stderr.write(" Unable to create egl sink")
sink.set_property('sync', False)
pipeline.add(sink)
for index in range(number_sources):
source_bin=create_source_bin(index)
if not source_bin:
sys.stderr.write("Unable to create source bin")
pipeline.add(source_bin)
sinkpad= streammux.get_request_pad("sink_%d" % index)
if not sinkpad:
sys.stderr.write("Unable to create sink pad bin")
srcpad=source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin")
srcpad.link(sinkpad)
streammux.link(pgie)
pgie.link(caps_filter)
caps_filter.link(tiler)
tiler.link(nvosd)
nvosd.link(transform)
transform.link(sink)
sinkpad = tiler.get_static_pad("sink")
if not sinkpad:
sys.stderr.write(" Unable to get sink pad")
loop = GObject.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", bus_call, loop)
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
number_sources = 2
run(number_sources)
