Segmentation Fault on passing mask, when postprocessing is bypassed to python in Deepstream 6.2
I wanted to post process the detections out of custom library
hence i had perprocessed it in this way.
This is my config_infer file
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
onnx-file=models/yolov8n-seg-psda.onnx
model-engine-file=engine/yolov8n-seg-psda.onnx_b1_gpu0_fp16.engine
gie-unique-id=1
network-type=100
network-mode=2
output-tensor-meta=1
infer-dims=3;640;640
and my function write back the bbox values is below
def add_obj_meta_to_frame(frame_object_data, batch_meta, frame_meta, label_names):
    """ Inserts an object into the metadata """
    # this is a good place to insert objects into the metadata.
    # Here's an example of inserting a single object.
    frame_object, masks = frame_object_data
    obj_meta = pyds.nvds_acquire_obj_meta_from_pool(batch_meta)
    # Set bbox properties. These are in input resolution.alloc mask array deepstream 6.2 in python
    rect_params = obj_meta.rect_params
    rect_params.left = frame_object.left
    rect_params.top =  frame_object.top
    rect_params.width = frame_object.width
    rect_params.height =  frame_object.height
    mask_param = pyds.NvOSD_MaskParams.cast(obj_meta)
    mask_param.width, mask_param.height = masks.shape
    allocated_mask_array = mask_param.alloc_mask_array()
    del allocated_mask_array
    final_mask = np.copyto(allocated_mask_array, masks.flatten())
    mask_params.height = frame_object.mask_height
    mask_params.size = frame_object.mask_size
    mask_params.data = frame_object.mask
    # Semi-transparent yellow backgroud
    rect_params.has_bg_color = 1
    rect_params.bg_color.set(1, 1, 0, 0.4)
    # Red border of width 3
    rect_params.border_width = 3
    rect_params.border_color.set(1, 0, 0, 1)
    # Set object info including class, detection confidence, etc.
    obj_meta.confidence = frame_object.detectionConfidence
    obj_meta.class_id = frame_object.classId
    # There is no tracking ID upon detection. The tracker will
    # assign an ID.
    obj_meta.object_id = UNTRACKED_OBJECT_ID
    lbl_id = frame_object.classId
    infoLog(f"LabelID: {lbl_id}")
    if lbl_id >= len(label_names):
        lbl_id = 0
    # Set the object classification label.
    obj_meta.obj_label = label_names[lbl_id]
    # Set display text for the object.
    txt_params = obj_meta.text_params
    if txt_params.display_text:
        pyds.free_buffer(txt_params.display_text)
    txt_params.x_offset = int(abs(rect_params.left))
    txt_params.y_offset = max(0, int(abs(rect_params.top)) - 10)
    txt_params.display_text = (
        label_names[lbl_id] + " " + "{:04.3f}".format(frame_object.detectionConfidence)
    infoLog(f"{rect_params.left}, {rect_params.top}, {rect_params.width}, {rect_params.height}, {obj_meta.object_id}, {obj_meta.obj_label}")
    # Font , font-color and font-size
    txt_params.font_params.font_name = "Serif"
    txt_params.font_params.font_size = 10
    # set(red, green, blue, alpha); set to White
    txt_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
    # Text background color
    txt_params.set_bg_clr = 1
    # set(red, green, blue, alpha); set to Black
    txt_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
    # Inser the object into current frame meta
    # This object has no parent
    pyds.nvds_add_obj_meta_to_frame(frame_meta, obj_meta, None)
On doing
I am getting segmentation fault core dumped, could you please guide me through.
Environment
TensorRT Version:
GPU Type:
Nvidia Driver Version:
CUDA Version: 12.2
CUDNN Version: 8.6
Operating System + Version: Ubuntu 20.04
Python Version (if applicable): 3.8
PyTorch Version (if applicable): Yolov8
Baremetal or Container (if container which image + tag): nvcr.io/nvidia/deepstream:6.2-devel
Relevant Files
Model:
https://github.com/ultralytics/assets/releases/download/v8.2.0/yolov8n-seg.pt
Steps To Reproduce
I have used this function altered from the reference deepstream_python_apps/apps/deepstream-ssd-parser/ssd_parser.py at 175d711184f407a42cba7d8ffebf875a126a74f7 · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
Could you refer to our latest demo deepstream-segmask to process the mask data?
Thanks for replying @yuweiw, But in the reference you have provided is with mask processing as output,
I am unable to write it back to the buffer, could you please help me on that.
OK. Could you confirm which line caused the crash? Also after allocing the mask array, why do you del that immediately?
I had even changed it later to this too.
But still final_mask = np.copyto(allocated_mask_array, masks.flatten())
this line is causing segmentation fault
OK. Could you print the shape and size of the allocated_mask_array and masks.flatten()?
allocated_mask_array is 160x160
masks.flatten is 25600,
But if you see here NvOSD_MaskParams — Deepstream Deepstream Version: 7.0 documentation from the githube code ref deepstream_python_apps/bindings/src/bindnvosd.cpp at 216ce3a08a61566cb3abcffdc0ddae30a57eb6b0 · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
it assign as flattened way
No. It depends on the dim of the data. If you use np.copyto to copy arrays with two different dimensions, you might get an exception.
