First my apologies if this is not the proper place to post this question.
I am very new to OptiX and rendering in general, but I am trying to determine if OptiX would be appropriate for a project I am working on for research. I have been working through the OptiX 7 Siggraph Course and concurrently digging through the SDK to try to better understand it.
I am having issues with the ray casting example. The example runs fine with the default settings(duck). However, I tried to add my own mesh and received a segmentation fault error. So I tried with some of the other provided models and got it to run for the water-bottle example, but also received segmentation faults for the plane and woman examples. This example seems to be very close to what I was trying to do, so I was hoping to use this as a jumping off point. Any help in understanding the issue and/or debugging is greatly appreciated.
Below is the ouptut:
/optixRaycasting -m …/…/SDK/data/Surface/surface.gltf
No file prefix specified, using default file prefix (output)
Processing glTF buffer ‘’
byte size: 5743224
uri : surface.bin
Processing glTF mesh: ‘geometry_0’
Num mesh primitive groups: 1
Num triangles: 238602
Has vertex normals: true
Has texcoords_0: false
Has texcoords_1: false
Has color_0: false
[ 4][ KNOBS]: All knobs on default.
[ 4][ DISKCACHE]: Opened database: “/var/tmp/OptixCache_benjamin/optix7cache.db”
[ 4][ DISKCACHE]: Cache data size: “3.6 MiB”
[ 4][ DISKCACHE]: Cache hit for key: ptx-129520-key64f683a73bdcb60323287ff636d6f4f8-sm_86-rtc1-drv550.54.15
[ 4][ COMPILER]:
[ 4][ COMPILER]: Info: Pipeline statistics
module(s) : 1
entry function(s) : 4
trace call(s) : 1
continuation callable call(s) : 0
direct callable call(s) : 0
basic block(s) in entry functions : 130
instruction(s) in entry functions : 3635
non-entry function(s) : 0
basic block(s) in non-entry functions: 0
instruction(s) in non-entry functions: 0
debug information : no
module(s) : 1
trace call(s) : 1
