I can run the encoder example, but the decoder segfaults on startup. I get the same results with nvidia driver v 375.
Any idea what could be wrong?
#0 0x0000000000000000 in ?? ()
#1 0x00007fae188b6291 in init () at dlerror.c:177
#2 0x00007fae188b66d7 in _dlerror_run (operate=operate@entry=0x7fae188b6130 <dlsym_doit>,
args=args@entry=0x7ffdd6f10770) at dlerror.c:129
#3 0x00007fae188b6198 in __dlsym (handle=<optimized out>, name=<optimized out>) at dlsym.c:70
#4 0x00007fae1732012f in ?? () from /usr/lib/nvidia-381/libGLdispatch.so.0
#5 0x00007fae173208b9 in ?? () from /usr/lib/nvidia-381/libGLdispatch.so.0
#6 0x00007fae18ac90cd in call_init (l=0x7fae18ca8000, argc=argc@entry=1, argv=argv@entry=0x7ffdd6f10848,
env=env@entry=0x7ffdd6f10858) at dl-init.c:64
#7 0x00007fae18ac91f3 in call_init (env=<optimized out>, argv=<optimized out>, argc=<optimized out>,
l=<optimized out>) at dl-init.c:36
#8 _dl_init (main_map=0x7fae18cdd1c8, argc=1, argv=0x7ffdd6f10848, env=0x7ffdd6f10858) at dl-init.c:126
#9 0x00007fae18aba30a in _dl_start_user () from /lib64/ld-linux-x86-64.so.2
#10 0x0000000000000001 in ?? ()
#11 0x00007ffdd6f12307 in ?? ()
#12 0x0000000000000000 in ?? ()
