Hi
Why do I get a segmentation fault when building an ICudaEngine running
// create the builder
IBuilder* builder = createInferBuilder(gLogger);
// parse the caffe model to populate the network, then set the outputs
INetworkDefinition* network = builder->createNetwork();
ICaffeParser* parser = createCaffeParser();
parser->setPluginFactory(pluginFactory);
std::cout << "Begin parsing model..." << std::endl;
const IBlobNameToTensor* blobNameToTensor = parser->parse(locateFile(deployFile).c_str(),
locateFile(modelFile).c_str(),
*network,
DataType::kFLOAT);
std::cout << "End parsing model..." << std::endl;
// specify which tensors are outputs
for (auto& s : outputs)
network->markOutput(*blobNameToTensor->find(s.c_str()));
// Build the engine
builder->setMaxBatchSize(maxBatchSize);
builder->setMaxWorkspaceSize(10 << 20); // we need about 6MB of scratch space for the plugin layer for batch size 5
std::cout << "Begin building engine..." << std::endl;
ICudaEngine* engine = builder->buildCudaEngine(*network);
assert(engine);
std::cout << "End building engine..." << std::endl;
// we don't need the network any more, and we can destroy the parser
network->destroy();
parser->destroy();
// serialize the engine, then close everything down
(*gieModelStream) = engine->serialize();
engine->destroy();
builder->destroy();
shutdownProtobufLibrary();
Thread 1 "sample_fasterRC" received signal SIGSEGV, Segmentation fault.
0x00007fffe7994ba7 in nvinfer1::Network::validate(nvinfer1::cudnn::HardwareContext const&, bool, bool, int) const ()
from /home/TensorRT-3/TensorRT-3.0.1/lib/libnvinfer.so.4
I can correctly build a cuda engine when running the jetson-inference samples. Does this mean that there is something wrong with the network I implemented?
