Viewed 24 times
I am trying to read the binary file
which is kernel.aocx
from the host code. But, I got a segmentation fault. I understand that segmentation fault
caused because of accessing memory that does not belong to me. But I am not sure why this happened in my code. Lines of codes for reading binary file are:
inline float Euclidean_distance(__global int* restrict array_point_A, __global int* restrict array_point_B) {
float sum = 0.0;
float w[20] = { 0.0847282, 0.0408621, 0.105036, 0.0619821, 0.0595455, 0.0416739, 0.0181147, 0.00592921,
0.040049, 0.0766054, 0.0441091, 0.0376111, 0.0124285, 0.0733558, 0.0587338, 0.0303001, 0.0579207, 0.0449221,
0.0530462, 0.0530462 };
for (int i = 0; i < 20; ++i) {
float a = array_point_A[i] - array_point_B[i];
float wieghted_distance = w[i] * (a * a);
sum += wieghted_distance;
return sqrt(sum);
__kernel void KNN_classifier(__global int* restrict X_train, __global int* restrict Y_train, __global int* restrict data_point, __global int* restrict array_X_set, __global int* restrict index_arr, __global float* restrict array_dist)
int k = 3;
for (int i = 0; i < 4344; ++i) {
for (int j = 0; j < 20; ++j) {
data_point[j] = array_X_set[i];
array_dist[i] = Euclidean_distance(X_train, data_point);
index_arr[i] = i;
int x;
for (int i = 0; i < 4344; i++)
for (int j = i + 1; j < 4344; j++)
if (array_dist[index_arr[i]] > array_dist[index_arr[j]])
x = index_arr[i];
index_arr[i] = index_arr[j];
index_arr[j] = x;
int array_Y_class_target[2] = {};
float CT[2] = {};
float SumOf_Each_class_distances[2] = { 0.0 };
int min_index = -1;
for (int i = k; i > 0; --i) {
for (int c = 0; c < 2; ++c) {
for (int j = 0; j < i; ++j) {
int index = index_arr[j];
if (Y_train[index] == c)
array_Y_class_target[c] ++;
float dist = array_dist[index_arr[j]];
SumOf_Each_class_distances[c] += dist;
if (array_Y_class_target[c] != 0)
CT[c] = (((float)k / (float)array_Y_class_target[c]) + (SumOf_Each_class_distances[c] / (float)array_Y_class_target[c]));
else
CT[c] = 1.5;
float min = 1.8;
int max_index = -1;
for (int r = 0; r < 2; ++r) {
float elem = CT[r];
if (elem <= min) {
min = elem;
min_index = r;
for (size_t r = 0; r < 2; ++r) {
float elem = CT[r];
if ((elem == min) && (r != min_index)) {
if (SumOf_Each_class_distances[0] < SumOf_Each_class_distances[1])
min_index = 0;
else
min_index = 1;
index_arr[i] = min_index; ;
