• Hardware Platform (Jetson / GPU): RTX3070, 24GB ram
• DeepStream Version: GitHub - NVIDIA-AI-IOT/deepstream_tao_apps at release/tao3.0
• TensorRT Version: TensorRT=8.0.1
• NVIDIA GPU Driver Version (valid for GPU only): CUDA_VERSION=11.4.1
**• How to reproduce the issue ? **: Running tao-converter
command for mask-rcnn-fp16.etlt results in segmentation fault and out of memory errors.
I’ve trained and exported a custom mask-rcnn model from TAO-3.0 toolkit (exported using tao mask_rcnn export in the following container: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.21.11-tf1.15.5-py3)
When I attempt to convert the fp16.etlt model file to an engine file for DeepStream inference the system fails with a segmentation fault.
The tao-converter command used is:
./tao-converter -b 1 -k nvidia_tlt -t fp16 -m 1 -d 3,832,1344
-o generate_detections,mask_fcn_logits/BiasAdd
/path-to-fp16.etlt
Error Message:
ERROR: [TRT]: 1: Unexpected exception std::bad_alloc
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1119 Build engine failed from config file
Any ideas on resolving this issue?
