Segmentation fault when extracting Jpeg image at probe
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2*
• Issue Type( questions, new requirements, bugs) error
While attempting to extract a JPEG image within a probe, I encountered a segmentation fault
Pipeline code
def make_element( element, name):
    logger.info(f"creating element {element} ----- {name}")
    element = Gst.ElementFactory.make(element, name)
    if not element:
        logger.error(f" Unable to create {element} ----- {name}")
    return element
Gst.init(None)
pipeline = Gst.Pipeline()
logger.info("Creating Pipeline")
if not pipeline:
    logger.error("Unable to initialize Pipeline")
streammux = make_element("nvstreammux", "Stream-muxer")
pipeline.add(streammux)
for idx, uri in stream_list.items():
    logger.info(f"Creating source_bin  for uri {uri} ID {idx}")
    # Create first source bin and add to pipeline
    source_bin = create_uridecode_bin(idx, uri)
    logger.info("Creating source_bin")
    if not source_bin:
        logger.error(f"Failed to create source bin for uri {uri} ID {idx}.")
        # API hit fot not connecting
    else:
        pipeline.add(source_bin)
# queue1 = make_element("queue", "queue1")
# pipeline.add(queue1)
streammux.set_property("batched-push-timeout", 25000)
streammux.set_property("batch-size", MAX_SOURCE)
streammux.set_property("gpu_id", gpu_id)
streammux.set_property("live-source", 1)  # need to check
streammux.set_property('width', frame_width)
streammux.set_property('height', frame_height)
pgie = make_element("nvinfer", "primary-inference")
pgie.set_property('config-file-path', "model_config.txt")
pgie.set_property("gpu_id", gpu_id)
pgie.set_property("batch-size", MAX_SOURCE)
pipeline.add(pgie)
nvvidconv = make_element("nvvideoconvert", "convertor")
nvvidconv.set_property("gpu_id", gpu_id)
pipeline.add(nvvidconv)
caps = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
filter = make_element("capsfilter", "filter")
filter.set_property("caps", caps)
pipeline.add(filter)
encoder = make_element("jpegenc", "encoder")
pipeline.add(encoder)
tee = make_element("tee", "tee")
# nvstreamdemux = make_element("nvstreamdemux", "nvstreamdemux")
pipeline.add(tee)
if (not is_aarch64()):
    # sink.set_property("gpu_id", gpu_id)
    mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
    # streammux.set_property("nvbuf-memory-type", mem_type)
    nvvidconv.set_property("nvbuf-memory-type", mem_type)
    streammux.set_property("nvbuf-memory-type", int(pyds.NVBUF_MEM_CUDA_DEVICE))
streammux.link(pgie)
pgie.link(nvvidconv)
nvvidconv.link(encoder)
encoder.link(tee)
for ID, uri in stream_list.items():
    # creating queue
    queue = make_element("queue", f"queue-{ID}")
    queue.set_property("leaky", 2)
    pipeline.add(queue)
    sink = make_element("filesink", f"filesink-{ID}")
    sink.set_property("location", "image_%05d.jpg")
    pipeline.add(sink)
    # connect tee -> queue
    padname = "src_%u" % ID
    teesrcpad = tee.get_request_pad(padname)
    if not teesrcpad:
        logger.error("Unable to create demux src pad ")
    queuesinkpad = queue.get_static_pad("sink")
    if not queuesinkpad:
        logger.error("Unable to create queue sink pad ")
    teesrcpad.link(queuesinkpad)
    # connect  queue -> fakesink
    queue.link(sink)
    sinkpad = sink.get_static_pad("sink")
    prob_func = partial(sink_pad_buffer_probe, ID=ID)
    sinkpad.add_probe(Gst.PadProbeType.BUFFER, prob_func, 0)
probe code
def osd_sink_pad_buffer_probe( pad, info,udata, ID=0):
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        logger.error("Unable to get GstBuffer ")
        return
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    if not batch_meta:
        return Gst.PadProbeReturn.OK
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
        except StopIteration:
            logger.error("debug1------------------------------->at the except ")
            continue
        source_id = frame_meta.source_id
        print("debug------------->", source_id, frame_meta.source_frame_height)
        n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
        print(type(n_frame))
        try:
            l_frame = l_frame.next
                break
How do you run this program, whether on host or docker?
What’s your cuda and driver verison ?
Can you shared all the configration files and sample code for me to reproduc this issue ?
Could you get a detailed log use this command line ?
GST_DEBUG=3 python3 your_app.py
I am running it on docker
Driver Version: 535.113.01 CUDA Version: 12.2
after checking the documentation i realized pyds.get_nvds_buf_surface supports only RGBA Frames, if that the reason whats causing the segmentation fault? what is the alternate way to extract jpeg frames at the probe from a batch of data?
Thank you
when the number of sources > 1 (probe is not added) i am getting this error
0:02:25.952837920   555 0x7fcc2c2a4700 ERROR         nvvideoconvert gstnvvideoconvert.c:4095:gst_nvvideoconvert_transform: buffer transform failed
later i upgarded to deepstream6.3 from 6.2 and changed jpegenc to nvjpegenc, since then i am not getting the error gst_nvvideoconvert_transform: buffer transform failed and i update the probe to
    if not gst_buffer:
        return
    if not batch_meta:
        try:
            continue
       peg_data = gst_buffer.extract_dup(frame_meta.batch_id, gst_buffer.get_size())
        with open(f"{source_id}/captured_frame-{time.time()}.jpg", "wb") as f:
                        f.write(jpeg_data)
        try:
                break
the problem i am facing is that some of the frames are corrupted
Maybe you can try nvjpegenc.
I think jpegenc can’t access the memory of memory:NVMM.
By the way, Can you share the full pipeline ? I can’t see the full pipeline from your code.
yes, i switched to nvjpegenc` and i can execute the process, but some of the saved images are corrupted.
jpegenc.py (7.1 KB)
I have tried your code through modify deepstream_test_1.py, It works fine.
Noticed that the data after your encoder was sent to tee. Did you modify it after the tee?
I guess this is why your picture is abnormal.
after tee its just queue and fakesink on each branch
tee >> queue >> fakesink
I am not editing the data after tee. I got proper images when i used demux instead of tee. I would like to know what caused the image corruption when i used it, Is it because the process in prob is slow that caused frame drop? or all branches of the tee accessing the buffer at the same time?
I believe that neither of these situations will cause the picture to be abnormal.
deepstream_test_enc_multisrc.py (9.8 KB)
I noticed that you input multiple pictures at the same time to form a batch.
I think it may be because nvjpegenc does not support batch input.
I can reproduce your problem using this sample
