Segmentation fault when using abstract interface with assumed shape
The code below compiles correctly, but produces a segmentation fault when run. The problem seems to be the abstract interface with assumed shape arrays: sub fails, but sub2 works. Other compilers (gfortran, ifort, nagfor) work as expected.
nvfortran 23.1-0 64-bit target on x86-64 Linux -tp skylake-avx512
NVIDIA Compilers and Tools
Copyright (c) 2023, NVIDIA CORPORATION & AFFILIATES.  All rights reserved.
module mymod
  use, intrinsic :: iso_fortran_env, only: real64
  implicit none
  private
  public :: mysub, mysub2
  abstract interface
    subroutine mysub(A, B)
      import :: real64
      complex(kind=real64), intent(in) :: A(:,:)
      complex(kind=real64), intent(out) :: B(:,:)
    end subroutine mysub
    subroutine mysub2(A, B, n)
      import :: real64
      integer, intent(in) :: n
      complex(kind=real64), intent(in) :: A(n,n)
      complex(kind=real64), intent(out) :: B(n,n)
    end subroutine mysub2
  end interface
end module mymod
subroutine sub(A, B)
  implicit none
  B = A
end subroutine sub
subroutine sub2(A, B, n)
  implicit none
  B = A
end subroutine sub2
program prog
  use mymod, only: mysub, mysub2
  implicit none
  complex(kind=real64) :: A(3,3), B(3,3)
  procedure(mysub) :: sub
  procedure(mysub2) :: sub2
  A(:,:) = (1.0_real64, 2.0_real64)
  B(:,:) = (0.0_real64, 0.0_real64)
  ! "sub" fails, but "sub2" works!
  call sub(A, B)
  !call sub2(A, B, 3)
  write(6,*) B
end program prog
Thanks for the report Jellby. I talked with one of our Fortran engineers and he agrees that it’s likely a compiler issue. Hence I filed a problem report, TPR #33040, and engineering will investigate.
He did suggest using submodules might be a better option for you, or at least as a work around:
% cat test2.f90
module mymod
  implicit none
  private
  public :: sub, sub2
  interface
     module subroutine sub(A, B)
       import :: real64
     end subroutine
     module subroutine sub2(A, B, n)
       import :: real64
     end subroutine
  end interface
end module mymod
submodule(mymod) submod
contains
    implicit none
    B = A
  end subroutine sub
    implicit none
    B = A
  end subroutine sub2
end submodule submod
program prog
  use mymod, only: sub, sub2
  implicit none
  call sub(A, B)
  !call sub2(A, B, 3)
  write(6,*) B
end program prog
% nvfortran test2.f90; a.out
 (1.000000000000000,2.000000000000000)  (1.000000000000000,2.000000000000000)
Here is another minimal program reproducing the same segmentation fault error. One can get it working if the explicit pointer defined with the same abstract interface is used instead of direct subroutine call.
subroutine sub(B)
  integer :: B(:)
  B = 1
end subroutine sub
program prog
  abstract interface
   subroutine mysub(B)
     integer :: B(:)
  end interface
  integer :: B(3)
  procedure(mysub), pointer :: p
  p => sub
  ! explicit pointer p works
  call p(B)
  write(6,*) B
  ! "sub" itself fails
  call sub(B)
  write(6,*) B
end program prog
The same trick works with the code of @Jellby. I guess it is the point that the compiler does not create the pointer (or does ill-defined one) automatically when using the abstract interface.
Hope it helps if the problem is not solved yet.
